VideoHelp.com Forum
Results 1 to 12 of 12
    Hi again,
    I noticed that the latest DVD I ripped, The Terminator, is out of sync. AutoGK's log mentions that there's a delay, I forget how much, but it doesn't specify whether it's positive or negative. Also, when I try to use the appropriate amount of delay in VirtualDub, it still doesn't sync 100%. I have to round up/down, tinker a bit, etc. before it looks proper.
    Why do these delays occur in the first place? How do I determine whether the delay is positive or negative? Why doesn't the A/V sync up, despite using the exact amount of delay specified in the log file?
    Is there such a thing as ripping a DVD without any delay? I'm getting a bit discouraged here
    Thanks in advance for your help,
    Justin
  2. How are you decrypting the DVD to the hard drive? If you're not decrypting the movie and only the movie (not the entire DVD), then go back and start over again. Most synch problems can be traced back to the decrypt.
    As for the delay, AutoGK takes account of the delay already. If it's out of synch it's for a different reason (like an improper decrypt).
  3. Run your avi (XVID) file through avimuxGUI. double click the file, highlight the out of sync audio and click run. Give your file a new name and let it save. Your file should now be fixed. Of course, I do this directly after running AutoGK. I haven't tried it after trying to manually adjust the audio. It may still work.
    Mark
    I used DVDFab to copy the DVDs to my drive. I'll check out avimuxGUI and see what happens. Thanks
    Crap. avimuxGUI doesn't seem to be compatible with Windows 7. It crashes the second I try to run it.
  6. Try running it in WinXP mode or as an Admin. It works for me and I am using Win7.
    Mark
    I can't run it in XP mode, 'cause I don't have enough RAM. I'm the admin too
  8. You tried opening it as an Administrator? Well then, I am sorry. I don't know what to tell you now.
    Mark
  9. Member ranchhand's Avatar
    FYI... I just used DVD Shrink to rip the latest Terminator and it worked perfectly. I deleted all the trailors and garbage, no problems.
  10. And you made a DVD, right? takearushfan is trying to make an AVI. Big difference. Also, if I read him correctly, you're talking about 2 different movies. He's doing number 1 and you number 4.
  11. Member ranchhand's Avatar
    Sorry about that - I don't see anything about AVI in his first post, guess I should have read all the posts thoroughly.
    Yes, I am making an AVI. I ended up just manually adjusting the problem in VDub's skew correction. What's odd is that the delay amount that the log file specifies is not accurate. I had to round up by around 250ms.
  1. autoGK started encoding out of sync
    By octeuron in forum Newbie / General discussions
    Last Post: 8th Jul 2010, 15:19
  2. AutoGK sound issues
    By SpaceMonkey52 in forum DVD Ripping
    Last Post: 26th May 2008, 03:37
  3. AutoGK Settings: Frame Rate Confusion
    By Tom Saurus in forum Video Conversion
    Last Post: 30th Sep 2007, 05:18
  4. autogk, audio out of sync
    By Disa in forum DVD Ripping
    Last Post: 30th May 2007, 15:03
  5. autoGK subtitle out-of-sync with audio?
    By cristolin in forum Subtitle
    Last Post: 16th May 2007, 00:14
