Hi,
there are loads of threads on here abouyt this software but I can't seem to find what I need so I'm hoping someone can help!
I have successfully installed all of the drivers and Ulead software onto my XP operating system,
And both the Ulead Video Studio software and Windows movie maker start to capture fine with Audio, however, about 5 mins into the video, even tho the VHS continues to play, on both programs the viewing screen and timer freeze, when I try to stop the capture, the programs refuse to respond and I have to either go into task manager or shut my pc down completely.
I've closed down all excess programs coz my pc speck is not brill, but it does meet the minimum specs listed on the accompanying CD.
Does anyone have any idea's why this might be happening and how to stop this?
Thanks in advance.
Thread: Easycap Capture, USB 2.0
As far as I have read/seen about Easycap it is quite resource hungry and unless you are capturing for a You Tube upload, it isn't very kind to lower spec PCs.
There are several videos on You Tube about Easycap; the most informative I found being this one:
http://www.youtube.com/watch?v=7Efkf...eature=related
Hope that this helps.Cole
hi and welcome to the forum.
what format are you capturing to? are you sure you have enough free space on the hard drive? is the hard drive formatted fat32 or ntfs? sounds like it ran into a error of some sort while writing the file.--
EasyCap USB 2.0 Video Capture requesting name & registration code Help Req
By Teac23 in forum CapturingReplies: 4Last Post: 21st Nov 2010, 22:22 -
EasyCap USB to S_Video Adapter Capture Card
By domainbug in forum ComputerReplies: 3Last Post: 7th May 2010, 20:51 -
Easycap usb large capture files
By visionman in forum CapturingReplies: 5Last Post: 4th May 2010, 17:23 -
EasyCAP 2.0 USB = No Sound on Capture????
By williamgibbs in forum Newbie / General discussionsReplies: 0Last Post: 24th Feb 2009, 08:15 -
Can Easycap Video Grabber Capture card USB 2.0 RCA be used to record Beta
By laslim in forum CapturingReplies: 1Last Post: 20th Sep 2008, 10:06
Statistics
Newest guides
Latest tool updates
New media comments
