I've been looking to see why a corrupt MOV video shows up as MPG, how I can fix them, and hope you guys can help! I searched the forums to check for similar questions.
-> Background: I deleted the wrong MOV file (~1Gb) from my full canon camera's memory card, and took two pictures (~20Mb) which undoubtedly over-wrote part of the video file. I'm using Win XP.
-> Question: is there a way to extract image frames from the file, or to tell if images are even there?
-> Attempt 1 : eImage Recovery found two video files: about 720 Mb, and about 40 Mb. eImage automatically gave the extension MPG which is wrong of course. No player (VLC, MPlayer, etc) is able to play them.
-> Attempt 2 : GSpot can't recognize a codec for any of the files.
-> Attempt 3 : a hex editor shows the header info is missing from the 720Mb file, and the footer is in the 40Mb file: I compared the recovered files to others that were intact to see what to look for.
-> Attempt 4 : only one video-fixing software was able to process a file, and it resulted in an IV41 (Intel) mpg according to GSpot, but this of course doesn't play either, and I have no idea why it should be an IV41; probably GSpot just randomly thinks it's IV41 when it isn't, since it's missing all sorts of data.
-> Attempt 5 : I tried adding in header and footer data to the broken file using a hex editor. Seems MOV files are very sensitive, since removing even one line from the middle of a working file results in it not playing... So manual manipulation is probably too complex.
Any ideas on how to get parts of the video back? Clearly there is a large chunk of *something* thereI'm willing to do a lot of work, or look for a service that can recover them.
Results 1 to 1 of 1
Nikon Coolpix corrupted .mov video file repair
By darrenpj in forum Video ConversionReplies: 3Last Post: 31st Mar 2012, 17:15 -
HELP! Damaged/Corrupted MOV file.
By neil wilkes in forum EditingReplies: 3Last Post: 13th Nov 2011, 07:09 -
I have a corrupted Quicktime MOV file I need to fix.
By Videogamer555 in forum RestorationReplies: 0Last Post: 5th Mar 2011, 00:51 -
Hexediting corrupted .mov file, please!
By darkie1213 in forum RestorationReplies: 2Last Post: 17th Nov 2009, 08:46 -
Corrupted converted .mov files
By Nintendo Fan in forum EditingReplies: 1Last Post: 21st Jan 2009, 18:26
