Wondering if there is any standalone program to copy a Windows XP hard drive byte for byte..... not using software like Norton or Acronis. Back in the days of Win 98 & ME, I had a program called XXCOPY on a floppy disk, all you had to do was connect
a second hard drive to your system and XXCOPY would copy the entire hard drive. Then you could remove your first hard drive
and install the copied drive as your main unit. Anything similar out there for Windows XP NTFS file system ? Thanks.
Thread: copying a Windows XP hard drive
Most retail hard drives come with a free clone utility. You can also go to the drive manufacturer's web site and download one for free -- as long as one of the drives is from that manufacturer. In my experience it's usually a crippled copy of Acronis.
Problem copying DVDs to hard drive (previously copied from videos)
By avz10 in forum RestorationReplies: 4Last Post: 2nd Mar 2010, 22:54 -
do you know a good freeware hard drive copying program?
By edong in forum ComputerReplies: 7Last Post: 20th Dec 2009, 08:29 -
Copying and converting files to external hard drive
By soxenme in forum Newbie / General discussionsReplies: 4Last Post: 25th Feb 2009, 17:16 -
Copying Your Hard Drive
By wulf109 in forum ComputerReplies: 6Last Post: 8th Feb 2008, 23:13 -
I want to reauthor DVDs without copying to the hard drive first.
By Big C in forum DVD RippingReplies: 2Last Post: 24th Jul 2007, 19:54
Statistics
Newest guides
Latest tool updates
New media comments
