VideoHelp.com Forum
Results 1 to 10 of 10
  1. I've uninstalled both DivX and xVid codec from my XP SP3 PC (WMP 11 installed).
    Both types of video can still be played. MPC-HC shows MPC Video Decoder (see below). How do I find out which codec is being used?
    Filter : MPC Video Decoder - CLSID : {008BAC12-FBAF-497B-9670-BC6F6FBAE2C4}
    - Connected to:
    CLSID: {CEA8DEFF-0AF7-4DB9-9A38-FB3C3AEFC0DE}
    Filter: C:\tmp\video.avi
    Pin: Video 0
    - Connection media type:
    Video: DivX 5 512x368 29.97fps 1632Kbps
    AM_MEDIA_TYPE:
    majortype: MEDIATYPE_Video {73646976-0000-0010-8000-00AA00389B71}
    subtype: Unknown GUID Name {30355844-0000-0010-8000-00AA00389B71}
    formattype: FORMAT_VideoInfo {05589F80-C356-11CE-BF01-00AA0055595A}
    bFixedSizeSamples: 1
    bTemporalCompression: 0
    lSampleSize: 63231
    cbFormat: 88
    VIDEOINFOHEADER:
    rcSource: (0,0)-(0,0)
    rcTarget: (0,0)-(0,0)
    dwBitRate: 1632945
    dwBitErrorRate: 0
    AvgTimePerFrame: 333667
    BITMAPINFOHEADER:
    biSize: 40
    biWidth: 512
    biHeight: 368
    biPlanes: 1
    biBitCount: 24
    biCompression: DX50
    biSizeImage: 1130496
    biXPelsPerMeter: 0
    biYPelsPerMeter: 0
    biClrUsed: 0
    biClrImportant: 0
    pbFormat:
    0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    0020: b1 ea 18 00 00 00 00 00 63 17 05 00 00 00 00 00 Бъ......c.......
    0030: 28 00 00 00 00 02 00 00 70 01 00 00 01 00 18 00 (.......p.......
    0040: 44 58 35 30 00 40 11 00 00 00 00 00 00 00 00 00 DX50.@..........
    0050: 00 00 00 00 00 00 00 00 ........
    "MPC Video Decoder" is MPCHC's internal Divx/Xvid decoder.
  3. They play fine in WMP as well. So there has to be other codec then. How can I find out?
    Disable MPCHC's internal Divx/Xvid decoder:
    View -> Options -> Internal Filters, Transform Filters (box)...
    Restart it, play a file with it, and see what decoder is in use. ffdshow maybe?
  5. Disabled that, and it still plays.
  6. MPC Video Decoder (and other filters from MPC) is also available as a standalone filter.
    Use Gspot:
    Proposed Codec Solutions and Tests > MS A/V > 1
    or GraphStudio (Render Media File... option).
    MPEG-4 ASP video with DX50 FourCC can be decoded by DivX, Xvid, 3ivX, ffdshow, decoder from MPC, decoder from Nero, ...
    VideoAudio.pl - Serwis o technologii wideo & audio
    You can see what filters are in use while playing in MPCHC. Right click on the video window and hover over Filters. You'll get a menu of filters currently in use. Select one for more properties.
  8. Tried GSpot first. It can tell the video is DX50 and codec is installed. But it won't show what codec is in used.
    GraphStudio worked, showed me Intervideo MPEG-4. Uninstalled WinDVD and now it won't play in WMP, only in MPC-HC. Strangely, even with all MPEG-4 internal filter disabled, it still plays fine in MPC. The only thing is it show MPC Decoder (low merit)
    What does this low merit thing mean?
    Thanks!
    Each filter has a "merit" -- a priority. When there are multiple filters that can decode a video the one with the highest merit is used. You can use filter editors to change merits, disable filters, etc: FilMerit, Radlight Filter Manager, DirectShow Filter Manager. GSpot also has a filter manager under System -> List Codecs...
  10. Originally Posted by cheerful
    ... and now it won't play in WMP, only in MPC-HC. Strangely, even with all MPEG-4 internal filter disabled, it still plays fine in MPC. The only thing is it show MPC Decoder (low merit)
    If required decoder is not installed in system, MPC uses its internal (even if it's 'disabled').
    So... actually it is not disable internal decoder, but a change to a lower priority - it seems that can't be completely off internal filters/decoders.
    BTW
    Some other video players can show used DitrectShow filters (like MPC), for example BS.Player or Zoom Player.
  1. AVI with DIVx or XVid codec?
    By Sierraguy in forum Newbie / General discussions
    Last Post: 8th Feb 2011, 10:47
  2. What is divx and xvid codec?
    By Azrail in forum Newbie / General discussions
    Last Post: 5th Oct 2010, 21:31
  3. Difference between divx and xvid, and the best codec available?
    By acommuter in forum Newbie / General discussions
    Last Post: 16th Jun 2010, 11:44
  4. Replies: 4
    Last Post: 5th Jun 2008, 11:47
  5. Replies: 3
    Last Post: 6th Aug 2007, 22:53
