I have found the same problems point above:
---> http://avidemux.org/admForum/viewtopic.php?id=5999
---> http://www.avidemux.org/admWiki/index.php?title=Cutting
---> http://www.avidemux.org/admWiki/inde...ing_MPEG_files
I am unable to save after editing from 2.4.3 (r4533) on Mac OSX 10.5.6 because of the above error, yet I always make cuts at I frames (using the double arrow buttons to move the edit point) and the display always shows an I frame (at the moment it's reading Frame Type: I (00) as the start of my video). I have no filters selected and have chosen 'Copy' for both Video and Audio content.
Any suggestions most welcome.
Many thanks - GeoffT.
Not the start of your video needs to be an I-Frame (that's always the case), the A-Marker must be set on an I-Frame!
Thanks for the reply. Sadly it makes no difference. I tried setting the A marker to the beginning of the file (which as you say is an I frame) and to another I frame in the file but the result is the same: 'The beginning frame is not a key frame. Please move the A marker.'
GeoffT.If your first frame is not an I-frame use the "double forward arrow" to skip to an I-frame. Move one frame back (single arrow). Click on B for B-frame. Select (menu) Edit->Cut to remove the first few frames.
Now your first frame is an I-frame.
I have the same problem, the frame IS an I frame. I can advance to a future iframe as well, and set the A marker there, same result when trying to "copy" a m2ts input file containing H.264 to mkv output. Simply want to change containers.
No matter what I do, the error comes up and I cannot save mkv.
For those who has the same issues. :Pusing the >> arrows, you probably keep landing on the wrong type of frame, regardless of what it shows in the preview.
I was having the same problem, but found that if i navigate manually with mouse when choosing the (A) inpoint rather than using the arrows, it lands on a frame that is usuable.
It'll be harder to have a precise in point, but it works everytime, and the >> arrows failed everytime.
Any others solutions for this problem, point here too.
Thanks.
best regards.
devil (johner)
Yes, use the two buttons that advance by I frame and it will then land on an I frame that it can deal with. There is a guide that Baldrick wrote covering this and showing the buttons.
http://www.videohelp.com/guides/how-...at-id1091#1091
Sometimes I have found that this still didn't work and I had to clear the edit points several times before it did work. I think that command is under the EDIT tab at the top. Or if that still didn't work I would exit the app and start it again.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Key frame editing?
By vato76 in forum EditingReplies: 3Last Post: 7th Jun 2011, 12:55 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Green frame at beginning of video, Why???
By Hittz in forum Newbie / General discussionsReplies: 9Last Post: 19th Dec 2008, 21:13 -
Any way to insert 1 frame image at the beginning of an mp4 (using AutoGK)
By cryptyk in forum DVD RippingReplies: 11Last Post: 10th Sep 2008, 22:03 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 12:28
Statistics
Newest guides
Latest tool updates
New media comments
