Greetings:
I would like to stream movies from an external USB HD to a Hi-Def HDMI HDD Media center Patriot Box Office via ethernet cable. For unknown reason, my Media center can see my network share drives PC connecting to a Belkin F5D7231-4 router but I am unable to access them even after I enter the admin user id and pwd and the share drives permission is set such that everyone can access to them. To work around this problem, I am thinking of getting a new router with an USB port and hook up the external USB HD directly to the router thus bypassing my PC. My choice has been narrowed down to Belkin F5D8235-4, D-Link DIR-655 and Linksys WRT610N. If it were you which one will you pick?
- My budget is $120 max (including a gift card of $54 from Best Buy).
- All my 3 laptop is Wireless G. My desktop, HDD Media Player, Blu-ray is wired to the router.
- My coverage range is about 25ft x 15ft
- My cable modem is Surfboard SB6120.
- I prefer a router manufacture that still has customer support in the US if at all possible.
Any help to pick up the best bang for the buck router would be greatly appreciated.
Originally Posted by pwangdel
Upgrade your "intranet" (home network) to gigabit performance relatively cheap w gigabit switches after the router
I stream blu rays all over my house thru gigabit switches AFTER the modem/router
I have a 8-port and a 5-port gigabit switch by D-Link, they both are reviewed @ newegg w/ an average of 5 eggs
I paid $25USD for my 5-port, now they are giving them away for under $5USD, if I were you i would buy a couple before they are sold out
D-Link 5-port gigabit switch $4 (5 eggs @ newegg from 132 reviews)
47mb/s sustained on my system
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127085
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Do you have a mixed XP/Vista/Win7 network? MS changed the way sharing works in Win7. Another way to encourage you to upgrade all systems to Win7. You can make simple shares work again though. Disable the password requirement in Win7, allow anonymous access to shares, and enable the Guest account.
Originally Posted by jagabo
ocgw
I had to disable PW sharing in W7 also to get sharing to work easily with the other PCs. I don't use PWs anyway on my PCs as I'm the only one that uses them. I set all sharing permissions on all the PCs. I have a gigabit router and four gigabit switches and everything works fine. Usually a ~45 - 70MB/s transfer rate throughout the LAN system. XP, Vista and W7 PCs connected. I block internet access with the router for my three video server PCs (Vista) and have the router firewall and Comodo to protect the others, so I see no need for PWs.
Media Center
By superc in forum LinuxReplies: 4Last Post: 7th Jan 2011, 19:39 -
Capturing on Hp Media Center PC
By MuffinMaYne in forum CapturingReplies: 0Last Post: 28th Nov 2007, 11:18 -
External media center HD
By ghiatti1 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Sep 2007, 08:09 -
Sharing TV - 1 Vista Media Center Server to Vista Media Center PC
By JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 01:33 -
Media Center Help
By rwheeler in forum Video ConversionReplies: 4Last Post: 25th Jun 2007, 13:06
