For years I have been using mpc to play all my videos. and with ffdshow its awesome I can have all videos play in the same size. But recently I thought I would try the home cinema version (64 bit for vista).
But no matter what I do I can not get the newer version to use FFDShow filters. I have shark007 codecs installed for vista.
Have you installed the 64-bit version of ffdshow? There should be a link to it on the VideoHelp Tools page for ffdshow.
As far as I know yes
UPDATE: OK I got FFDShow working ... BUT its only showing about half the screen... It's like its on zoom in or something but its not...... HELP!!!!!!
PUPDATE AGAIN... I uninstalled everything and reinstalled making sure mpc home cinema and ffdshow were the 64 bit versions... I think there was/is an issue with the shark007 codecs the interface is the 64 bit version but not all the codec are... I can no longer access ffdshow since making sure the 64 bit version was installed. All seems to be working however as long as I do not go through the shark007 thing. Yet it does say on the mpc home page that it is supposed to be compatable with it. So any help anyone can give in getting everything working in tandom would be good. Otherwise I guess I will just have to leave the shark007 codec thing out for now as I do not seem to need it at the moment.
The only good codec pack is the on the you don't install on your PC.
MPC Home Cinema - How to Resume Play at the Same Point?
By blizno in forum Software PlayingReplies: 1Last Post: 13th Mar 2009, 17:03 -
MPC Home Cinema will not play DivX
By DarrellS in forum Software PlayingReplies: 15Last Post: 12th Nov 2008, 15:32 -
playing .MKV file in MPC Home Cinema, no subs
By THX-UltraII in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2008, 08:22 -
MPC Home Cinema and FLV
By majax79 in forum Software PlayingReplies: 0Last Post: 8th Jul 2008, 18:29 -
Saving Thumbnails in MPC Home Cinema
By majax79 in forum Software PlayingReplies: 1Last Post: 15th Jun 2008, 04:34
