OK, I've bought one of those cheapo capture devices, the Easycap DC60 USB plug-in.
Installed the drivers from the disc OK, but when I try to capture using Ulead I get an error message saying
Capture Module Initilization failed
Open Driver failed
Cannot create the video capture filter
15064:10:1
I can record using Windows Movie Maker and WINAVI capture. HOWEVER, the picture is riddled with lines as if its not reciving the signal properly (see picture below), plus the picture doesn't flow, it keeps pausing/stuttering as if the processor can't keep up with the picture.
However, I can capture fine off my built in webcam in all functions.
I've tried downloading newer drivers, but the problem remains.
I'm using an Acer aspire laptop, with the following specs.
Microsoft Windows XP Media Centre SP2
AMD Turion 64 X2 mobile technology TL-52
1.60GHZ, 1GB of RAM
Any ideas what could be causing this or how to cure it?
TIA
Thread: Easycap driver problem
try installing the k-lite codec.
my drivers are still not properly installed
but now it doesn't seem to matter. weird.
Thanks for the reply.
Well, after trying differant codecs and drivers, trying it on differant machines and doing much googling on the issue, I concluded there was obviously a problem with the device itself.
I did actually eliminate the fuzzy picture by plugging the device directly into my USB port and NOT using the extension lead. However the audio problems persisted, so sent the unit back for a refund.
Seems these so-called Easycap devices are actually cheap chinese copies, which is why so many are fraught with problems.
So, have decided to pay the extra tenner and get one of the new official EZCap devices.
Easycap DC60+ STK1150 vs. STK1160 driver
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2012, 08:02 -
EasyCap Video Adapter Driver for Windows 7 64-bit
By Naymark.com in forum CapturingReplies: 4Last Post: 26th Mar 2012, 01:08 -
easycap driver installation and use
By cville in forum Newbie / General discussionsReplies: 2Last Post: 19th Sep 2011, 11:11 -
EasyCap driver
By ronfarnham in forum Newbie / General discussionsReplies: 3Last Post: 16th Sep 2011, 21:15 -
EasyCap Video Adapter Driver for Windows 7 64-bit no spam
By wrathofbod in forum CapturingReplies: 3Last Post: 16th Sep 2011, 21:13
Statistics
Newest guides
Latest tool updates
New media comments
