Hello there, first message here as you can guess![]()
I'm currently using TMPGEnc to encode my video and audio elementary streams, burning them later with TMPGEnc Authoring Works.
I have heard, anyway, that it is better to encode an elementary audio streams NOT with TMPGEnc but with other programs, for better quality results and major compatibility.
Is it true? If it is, what kind of programs can I use for audio?
Thanks in advance!
Thread: MPEG encoding for DVD
Yes.I have heard, anyway, that it is better to encode an elementary audio streams NOT with TMPGEnc but with other programs, for better quality results and major compatibility.
Is it true?
I've always used toolame.exe (version 0.2k) OR twolame.exe (version 0.3.10b).If it is, what kind of programs can I use for audio?
P.S.: You can configure TMPGEnc to use toolame, instead of its internal MPA encoder.
Heh? I thought TMPGEnc used licensed ac3 encoding?
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By vaporeon800 in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
The best MPEG 2 encoding software?
By whatever911 in forum Video ConversionReplies: 17Last Post: 1st Nov 2011, 06:12 -
H.264 to MPEG-4 encoding recommendations?
By sjk in forum MacReplies: 0Last Post: 10th Jan 2008, 15:23 -
MPEG editing without re-encoding
By AlanD in forum EditingReplies: 3Last Post: 23rd Nov 2007, 04:52 -
TV tuner with hardware MPEG encoding
By mb508 in forum CapturingReplies: 7Last Post: 19th Sep 2007, 07:52
