I get this error C00D1199: Cannot play the file
But I have divx and fddshow and wmp10 and real media player. Any idea?
Thread: cannot play avi
VLC works. But I thought fddshow usually has the codec that plays 90% of all avi/mpg/mp4, etc
So what are the codecs? It could also be that the file isn't really an AVI file and you don't have an appropriate file reader/splitter installed.
Not all of ffdshow's decoders are necessarily enabled, in a default install. As poisondeathray mentioned, use GSpot or Mediainfo - first to verify that it actually is an AVI, then to see what codecs were used to encode the video and audio. VLC has a way to check this, but the last time I looked at it, it didn't provide as much information as I'd liked.
Once you know what codecs it uses, you can check ffdshow's configurations (all three of them - VfW video, DirectShow video, and audio), and see whether or not ffdshow supports them, whether or not they're set to 'disabled.'If cameras add ten pounds, why would people want to eat them?
avi won't play
By fabre in forum Software PlayingReplies: 2Last Post: 24th Aug 2011, 23:26 -
data avi .hdtv.avi-fqm.wont play on set top recrder
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2009, 14:55 -
How to Play avi files
By drstew in forum Software PlayingReplies: 21Last Post: 30th Mar 2009, 12:15 -
play AVI on tv
By protectyanek in forum Portable VideoReplies: 4Last Post: 21st Jan 2009, 22:41 -
Cannot play avi?
By jyeh74 in forum Newbie / General discussionsReplies: 8Last Post: 29th Jun 2007, 07:22
