Is there a noticeable difference in picture quality in the 2 formats?
Thread: Blu Ray 720p vs 1080p
If they were prepared correctly (i.e. adequate bitrate and encoding settings), and from a proper source (not uprezed, and not from a low quality HD source like a consumer camcorder), and you have an appropriate way of viewing them (i.e. at least 1920x1080 high quality HDTV or monitor) , then yes, there is a big difference. There are >2x the number of pixels
+ the size of the TV
yes, in relation to viewing distanceOriginally Posted by MJA
In what context ?
If you are talking about putting the same amount of video into the same space, you may find that the trade off is between resolution and bitrate artefacts.
There certainly is a difference, however the result is still far better than standard definition (e.g. DVD)
One difference is that 720p is the only progressive format on bluray that allows higher framerates like 50 fps or 59.94 fps.
In my opinion, "quality" equals clarity and for commercial products shown on TVs, perceived quality depend more on cinematography than it does on the number of pixels it takes to fill up the screen. I have many DVDs that show more "quality"(clarity) than some of my BRs. The cleanest clip I have is a 720p clip shot with lighting so good that every item on the screen crystal clear.
Tony
Question about Blu Ray subtitles (merging 1080p subs to 720p movie)
By prickly in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Jan 2012, 02:13 -
Blu-ray (1080p) menu template .PSD? Anyone got one?
By Asterra in forum Authoring (Blu-ray)Replies: 4Last Post: 18th Jul 2009, 16:50 -
DV AVI to 1080p? Thence Blu Ray?
By Maxwellbest in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 15:45 -
x264 1080p blu-ray files
By eric11111 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Dec 2008, 09:48 -
Will 720P and 1080P dvdr discs play on a Non Blu Ray DVD Player?
By donfm in forum Newbie / General discussionsReplies: 21Last Post: 31st Mar 2008, 14:45
