VideoHelp.com Forum
  1. Hi.
    I've bought Creative inspire P5800 for 2years ago.
    But only 2 out of 5 speakers work...
    The weird thing is that when i plug in the green cable in the green hole, 2 speakers work.
    when i put in the black cable in the green hole, 2 other speakers work...
    Some one knows what the problem is?
    Thx /Robin.
    Greets Robin!
    Baldrick is my uncle, Proud ;)
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Depends on your audio card, onboard or PCI. Some have jacks for all surround channels. The green one is usually just stereo. My motherboard uses three or four jacks for surround, though I use a separate surround amp instead hooked to my speaker system.
    You would have to adjust your audio card settings for surround, 5.1 audio or similar, and find out which jacks are used for the different channels. Telling us what motherboard and/or audio card you have would help considerably.
  3. The audio card is named Somthing with Sound blaster... and i have no idea what the motherboard is named
    Greets Robin!
  4. Sound Blaster X-Fi i guess
    Greets Robin!
  5. Mod Neophyte Super Moderator redwudz's Avatar
    Not really familiar with that card, but it should operate your surround speakers. I would go through the manual for the card and see what the proper hookups and settings are. A lot of motherboards also have surround sound output these days, but even with those, you need to go into the sound cards software control panel and set it for 5.1 or similar audio configurations, then plug your speakers into the correct output jacks.
    5.1 is the most basic surround mode, with the two front stereo speakers, two rear speakers and a center channel speaker. The '1' after the '5' designates a subwoofer. 6.1 adds a 'rear center' output, 7.1 adds two 'rear center speakers'. You need a source for surround sound, such as a DVD, to properly test the setup, along with a software player that you set to surround output. The front center channel speaker should be the dialog, and the others just do 'fill in.'
    With my system, I output digital audio (coaxial) to a separate surround amp, then to my speaker system, so I don't use computer speakers at all.
  6. I'm a Poll Super Moderator johns0's Avatar
    The plugs are green for the 2 front speakers,black for the surround sound and orange for the woofer/center speaker for the sound blaster x-fi,one of the most popular sound cards out there.
    You have to go to Creative Audio Control Panel and set the speakers to 5.1,setting it in windows sound doesnt work.
    Ben Johnson-I didnt take any stereos!
  7. Oh Thanks johns0
    i will try that out when my computer is done with som installation
    Greets Robin!
  1. Creative Zen TV out...
    By divxmpegjpeg in forum Newbie / General discussions
    Last Post: 5th Feb 2010, 09:43
  2. divx to creative zen
    By dynamix1 in forum Video Conversion
    Last Post: 27th Jan 2009, 19:37
  3. Creative Zen question
    By marlo in forum Newbie / General discussions
    Last Post: 14th Aug 2008, 16:52
  4. Possible alternative to the Creative Zen?
    By Steppanyaki in forum Portable Video
    Last Post: 24th May 2008, 23:31
  5. Are you creative at all?
    By yoda313 in forum Polls
    Last Post: 12th Sep 2007, 13:19
