VideoHelp.com Forum
    Guys sorry I hate being the newbie and have the dumb question but here goes. I copied a hack of this site to set my new DVD recorder an LG HB 954WA to all regions. I downloaded the file and did everything perfectly except read the instructions! I put the disk into the DVD player and saved region code "1" ie US etc however I meant to save "0" so I could use for all areas. I'm in Australia and its code 4. I tried to redo the disk twice including a fresh disk to reset the region but it now wont accept the disk with the hack on it and keep saying "check disk" like it needs to be in an American format.... Jesus what have I stuffed up now! Any help will be fantastic... John
    PS $100 Aussie dollars to whoever gives me the way to get it to work!
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Probably better asked and answered in our DVD & Blu-ray Players forum. Moving you.
    And welcome to our forums.
    Got the PM. I don't really have an answer for this one. Sorry.
  4. Member victoriabears's Avatar
    do not offer money, we are all friends here.
    okay, if you hacked the player with hacked firmware, my first suggestion is to try the disk you did the hack with again, sorry if you have tried this, as if it hacked the player to region 1 then my logic would be it will now hack it to region zero.
    Or
    look at this link
    http://www.lge.com/au/support/produc...alTab=drivers#
    and download the original firmware and try to set it back to that and then re hack to region zero.
    Just FYI, backups of dvd\s are always region free so that might help unless you are trying to play other than region 1 blu rays
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
    Thanks Victoriabears
  6. Member netmask56's Avatar
    Have you tried burning a file to a disc in the burner? Region coding will only kick in if you put a DVD from say the UK or Australia if in fact you have changed the RC to region 1 - it sounds like the original data disk with the patch is faulty or the firmware update you did simply failed and corrupted the firmware. I would look around for the o0fficial LG update file for region 4 and try to get it back to normal first. OF course if the firmware patch failed and corrupted the drive you are looking at finding repair software if it exists or a new drive.
    TheVoiceIsAnotherPerson ~ http://www.openwiz.org/wiki/ProjectX ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung LA40R7 LCD TV ~ Windows 7 & MAC G4
  1. Being able to set region code in LG BD550 blu ray player
    By bevivek in forum DVD & Blu-ray Players
    Last Post: 22nd Oct 2011, 06:11
  2. Replies: 0
    Last Post: 27th Dec 2009, 18:42
  3. how to change DVD player region code on Toshiba SDk 730
    By sashatheman in forum DVD & Blu-ray Players
    Last Post: 12th Dec 2009, 06:17
  4. citizen c201 dvd region code change
    By citizen007 in forum Newbie / General discussions
    Last Post: 21st May 2009, 10:25
  5. can't change region code on Samsung DVD-VR330
    By yorkshire lass in forum Newbie / General discussions
    Last Post: 7th Nov 2007, 09:47
