    Heres what i have: mkv, avi, ac3, and sub files. the mkv and avi are videos of the same thing, but the mkv is better quality. the first audio track of the mkv and the avi are the same.
    the avi file has a secondary audio track that i want to extract and add to the mkv file as a second audio track. i also want to add the ac3 file as a 3rd audio track to the mkv file.
    the avi file has subtitles that i want to add to the mkv file, but the sub file has the same subtitles except it doesn't seem to sync up with the video when i play the mkv and sub file together in vlc.
    to summarize, i want the video from the mkv file, the second track of the avi file, the ac3 file as the 3rd audio track and subtitles from the avi or the sub file.
    so how would i go about doing this? a mac based solution would be preferable.
  2. Mr. Computer Geek dannyboy48888's Avatar
    load mkvmerge (in linux the command in mmg , the package is mkvtoolnix) and load all the files. select and de-select the tracks you don't want and hit merge the output should have all the tracks you selected in one nice container. enjoy
    if all else fails read the damn manual
    i'm not familiar with linux at all. is there another way?
  4. Mr. Computer Geek dannyboy48888's Avatar
    http://www.bunkus.org/videotools/mkv...downloads.html don't have a mac to test it on but same concept
    http://www.bunkus.org/videotools/mkvtoolnix/downloads.html don't have a mac to test it on but same concept
    perfect! i had to find an .srt file online, but i have the file i wanted now! Thanks!
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Movin you to our MAC section.
    cheers for this app, the prog even helped me guess re-sync my 2nd audio track.
  1. .Mkv file: Extract, convert, and add suctitle to DVD?
    By Super Warrior in forum Subtitle
    Last Post: 11th Dec 2007, 19:47
  2. How to add AC3 file to already existing menu
    By chrishallowell in forum Authoring (DVD)
    Last Post: 14th Sep 2007, 13:32
  3. extract mkv video file to avi
    By dyl4u2000 in forum Video Conversion
    Last Post: 5th Jul 2006, 22:08
  4. How to convert/extract avi from mkv file
    By cthulhu in forum Newbie / General discussions
    Last Post: 15th Jan 2006, 16:16
  5. How to add subtitle to an existing .mpg file?
    By blackheart in forum Editing
    Last Post: 20th Jan 2004, 19:03
About   Advertise   Forum   RSS Feeds   Statistics   Tools
