VideoHelp.com Forum
    Current DVD Recorders in both PAL+NTSC available? Do you know any?
  2. Member edDV's Avatar
    Difficult enough to find NTSC only DVD Recorder models.
    I capture PAL with my Canopus ADVC to the computer.
    Or, are you only wanting PAL playback?
    http://www.kiva.org/about
    No I mean, is any DVD HDD or normal recorder able to record in PAL and NTSC in the same recorder?
  4. Member victoriabears's Avatar
    I always like to know the "why", do you want one?
    http://www.bhphotovideo.com/c/produc...B_HDD_DVD.html
    http://www.bhphotovideo.com/c/produc..._Recorder.html
    is my recommend, do bear in mind that these will only record in either ntsc/pal not convert,,therefore you need a pal/ntsc tv to monitor the results.
    Years ago the daytek recorders used to take a pal input and record in pal and convert to ntsc for the output, I also have a very fragile Curtis dvd recorder )same as RJ electronics) dvd recorder which does the same.
    http://www.newegg.com/Product/Produc...82E16882107048
    Also older Philips but the picture quality is horrible
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  1. Current DVD Recorders available?????
    By Regor21 in forum Newbie / General discussions
    Last Post: 22nd Jan 2012, 09:43
  2. Current US DVD players that can handle the PAL format...
    By VDubMike in forum DVD & Blu-ray Players
    Last Post: 6th Oct 2011, 23:00
  3. pal 60 dvd recorders
    By victoriabears in forum Capturing
    Last Post: 26th Aug 2011, 02:19
  4. What current recorders have flexible/incremental recording?
    By Bix in forum DVD & Blu-ray Recorders
    Last Post: 31st Oct 2008, 12:07
  5. DVD HDD recorders -- current best makes?
    By Trollheart in forum DVD & Blu-ray Recorders
    Last Post: 6th Mar 2008, 08:21
