Trying to capture DV from my Digital8 cam to Vegas Pro 8 which I'm brand new to. When I go to capture and specify DV as the source, I get a message "The device Cirrus Logic USB-DVR2 Source' could not be opened.
XP recognizes the camera which I've got plugged in via the Audigy Firewire interface on the breakout box, bells all over the place and it asks me if I want to capture if with Pinnacle or Nero but nuthin' on Vegas.
Any ideas?
I've attempted to log onto the Sony Vegas forums but it's proving to be a hassle. Keeps asking me to enter my software SN and machine number over and over.
Thanks.
So many issues.Originally Posted by brassplyer
1. Try WinDV for capture then import the DV-AVI file into Vegas. Your Vegas capture preferences may be set incorrectly.
2. The Audigy Firewire interface is proprietary and needs a Creative Labs driver. Check XP device manager for the IEEE-1394 port status.
3. "The device Cirrus Logic USB-DVR2 Source' could not be opened" further indicates problems with Vegas preferences or the Audigy Firewire driver interface.
4. Pinnacle and Nero are known for seizing the Firewire ports in older versions making them unavailable to other applications.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I'm confident that part of it is up and running, otherwise Pinnacle wouldn't recognize it. I *can* capture with Pinnacle, WindDV, etc. but I'd like to be able to do it all from within Vegas.Originally Posted by edDV
I'd bet the issue is within Vegas, but I haven't found the magic checkbox yet. If I could get into the Sony forums I'm sure it would help but there seems to be a snafu there.3. "The device Cirrus Logic USB-DVR2 Source' could not be opened" further indicates problems with Vegas preferences
Apparently it was a registry issue. This fix worked.
http://www.custcenter.com/cgi-bin/so...65&p_topview=1
Bad Dazzle
And I don't even have a Dazzle device.Originally Posted by edDV
Audigy must use the same Cirrus Logic part.
Sony Vegas Pro 10
By av.sorong in forum EditingReplies: 16Last Post: 9th Oct 2011, 12:27 -
VHS tapes, Hauppauge capture cards, interlacing, and Sony Vegas Pro 9
By othersteve in forum RestorationReplies: 6Last Post: 10th Sep 2009, 07:35 -
Help With Sony Vegas Pro 8?
By Olivia Bishop in forum EditingReplies: 9Last Post: 2nd Mar 2009, 16:20 -
Vegas is rendering frames it shouldn't
By tripecac in forum EditingReplies: 9Last Post: 16th Jul 2008, 12:26 -
Sony Vegas Pro 8 Capture in 16.9
By Ben17 in forum CapturingReplies: 18Last Post: 25th Apr 2008, 01:30
