So I have been trying to use meGUI, and i love it.. but no matter what I do, and i have tried everything i have been suggested and more, but audio gets out of sync with meGUI.
I was wondering if there was something else... doesnt have to be as complex or robust as meGUI, that would convert a DVD I have to an Xvid or Divx.
there has to be something there just for this, where it doesnt only server the video, but also serves the audio frame by frame, making sure they match up just like the .Vob s do? Instead of demuxing, serving video then muxing back? I dont care about speed at this point, i have spent almost a week on trying to make sound sync... so if this thing takes a day and it works i dont care.
Results 1 to 9 of 9
Staxrip!
And if you source is a newer commercial dvd be sure to use anydvd or dvdfab decrypter to decrypt.
If you're looking for something simple that'll make stuff that will reliably play in DivX devices (e.g. PlayStation 3, certified DVD players or TV with USB), you can use DivX Converter for free - it's part of the DivX 7 download from DivX.com. Currently, the trial part of DivX Converter only pertains to creating H.264/MKV files, but you can continue to make .divx files for free.
If you want something that gives you more settings and control, I'll agree that StaxRip has a nice interface.
I have been using the Celtic Druid build of Fairuse Wizard - which is straightforward and seems to do a good job. Does Staxrip offer any advantages over this?
thats one crazy name, can you link to it?Originally Posted by Chopmeister
Link to what? The programs mentioned are already linked. Click one and see.Originally Posted by Chrushev
I have had excellent results wth Handbrake(xvid supported older build),and AutoMen. Staxrip proved so so for me! I once used AutoMKV and had loads of problems with encodes eg undersized/oversized files, video audio sych etc. However some swear by it and have had no major problems. The options in AutoMKv are not for the faint hearted and there is a good support sheet out there to read here:
http://www.64k.it/andres/data/a/Auto..._Tutorial.html
I occasionally had synch problems with the excellent AutoGK-and now use it only fleetingly for resizing full frame to 16.9 or removing grain from video due to super VDubmod plugins, because it is not in development anymore and it does not support a lot of newer formats. I just use AutoMen and get super in synch encodings. Download link below.
http://forum.doom9.org/showthread.php?p=1018336
Try AutoMen, but decrypt your dvd using said driver: Fox tool. Fairuse Wizard does not decrypt a dvd like all the encoding tools mentioned here due to legal issues, so bear that in mind! Only DVDx does it(also No1 DVD Ripper) with special options, but you have to buy that to get advantage. Freeware version does not have this feature and is restricted. Older full option builds may still be available, but probably won't support Vista or Win 7.
[quote="porfitron"]If you're looking for something simple that'll make stuff that will reliably play in DivX devices (e.g. PlayStation 3, certified DVD players or TV with USB), you can use DivX Converter for free - it's part of the DivX 7 download from DivX.com. Currently, the trial part of DivX Converter only pertains to creating H.264/MKV files, but you can continue to make .divx files for free.
As a regretful customer who bought the above download, I sure hope you can produce a more reliable Converter version in the future ... and that my money will not then have been wasted entirely.
autogk
nothin easier or better'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Jan 2012, 07:07 -
XViD Conversion: Professional solution?
By plugues in forum Video ConversionReplies: 9Last Post: 7th Sep 2010, 12:16 -
Importing xvid and divx into vegas - a solution ?
By BJ_M in forum Video ConversionReplies: 55Last Post: 13th Apr 2010, 15:16 -
Best Solution for DivX/XviD on a TV (Apple TV or Media Center Extender)
By fletch407 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Jan 2008, 01:08 -
Easiest TV Show DVD to Xvid Solution?
By nickolasj80 in forum DVD RippingReplies: 1Last Post: 28th May 2007, 13:07
