VideoHelp.com Forum
Results 1 to 10 of 10
    Decided to purchase PRO version since freeware version worked well. Installation and registration worked OK, but on trying to start PRO version I get two Exceptions one after the other and the application does not start.
    So now I am stuck.
    The Exception messages are as follows:
    First Message
    Version: VOB2MPG PRO
    Build: 3.0.0210
    Type: System.Runtime.InteropServices.COMException
    Source: System.Windows.Forms
    Message: Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
    InnerException:
    StackTrace: at System.Windows.Forms.UnsafeNativeMethods.CoCreateI nstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
    at System.Windows.Forms.AxHost.CreateWithoutLicense(G uid clsid)
    at System.Windows.Forms.AxHost.CreateWithLicense(Stri ng license, Guid clsid)
    at System.Windows.Forms.AxHost.CreateInstanceCore(Gui d clsid)
    at System.Windows.Forms.AxHost.CreateInstance()
    at System.Windows.Forms.AxHost.GetOcxCreate()
    at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
    at System.Windows.Forms.AxHost.CreateHandle()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.AxHost.EndInit()
    at VOB2MPG_PRO.DVDPlayerCtl2.InitializeComponent()
    at VOB2MPG_PRO.DVDPlayerCtl2..ctor()
    at VOB2MPG_PRO.xfed3de3bc2a8e64d.x85601834555fb7d5()
    at VOB2MPG_PRO.xfed3de3bc2a8e64d..ctor(String[] args)
    at VOB2MPG_PRO.x867eb3246b182488.xc447809891322395(St ring[] xce8d8c7e3c2c2426)
    Second Message
    Build: 3.0.0210
    InnerException:
  2. Member ChrissyBoy's Avatar
    Looks like your Microsoft Video Control is not registered....
    Can you open a Command Prompt and type:
    regsvr32 c:\WINDOWS\system32\msvidctl.dll
    Hit return and then restart the program.
    Thanks for such a quick response.
    I registered the dll and received a success response message. However it did not solve the problem. I still get the same exception.
    What next?
    Jamie
  4. Member ChrissyBoy's Avatar
    What OS are you using?
    I am trying to use it under Windows Home Server, since the output files will be stored on the server, and it has a DVD reader attached. Normally I use My Movies to rip the DVDs, but this cannot handle multiple features. The freeware version 3.0 worked OK under WHS, so I assumed that the PRO version would also work.
    Jamie
  6. Member ChrissyBoy's Avatar
    Is it 64bit or 32 bit?
    32-bit. I think it is basically a cut down version of Windows Server 2003
  8. Member ChrissyBoy's Avatar
    Ok. Can you email me..... I will send you a build which is more likley to work on a server OS.
    I am having the same exact problem. The non-pro version worked fine under both Windows Home Server (Win2003) as well as Windows 2008 R2 X64 (which is basically a server version of Windows 7).
  10. Member ChrissyBoy's Avatar
    Can you also email me for a build which is Server friendly? In the meantime I am working on a fix for this.
  1. VOB2MPG PRO can not start, please give me a refund
    By xiaominghuang in forum SVCD2DVD & VOB2MPG
    Last Post: 1st Feb 2012, 23:17
  2. VOB2MPG PRO can not start
    Last Post: 15th Oct 2011, 20:45
  3. Replies: 4
    Last Post: 12th Jun 2010, 13:21
  4. Replies: 3
    Last Post: 5th Dec 2009, 07:50
  5. Replies: 7
    Last Post: 16th May 2007, 03:53
