I have a JVC 30GB hard drive camcorder and I'd like to compile a series of photos into a video film.
I'm not sure how I can do this.
I have a tripod for the camcorder, but don't have a clue about how I could set up a photograph to fill the viewfinder, then switch out to the next photo and so on to make a film.
I've found that I don't like the photograph quality of this camcorder, the photos look sharp when you are taking them but when I print them out on my HP Photosmart printer they are grainy.
I have an Fujipix f50 digital camera that takes good pictures.
The photos are a mixture of Polaroid instamatic and other point and shoot cameras over the years.
It would seem I'd need some piece of equipment to hold the photographs, but don't know how I could switch the pictures without it appearing on the camcorder footage.
I'd appreciate your help.
Results 1 to 9 of 9
You're going about this the wrong way. You need to scan the photos onto your hard drive, do any touching up as required (Photoshop, whatever), then assemble them into a video sequence (with transitions etc, if you want) using a slideshow app such as DVDSlideshowGUI (my all-time favourite - and free!).
Yes, scan them!
If you want something creative, then Sony Vegas (including the new-ish extremely cheap version) will let you zoom/pan/crop/slide photos, and use transitions between the photos, all with fairly little effort. The video output format can be almost anything you choose.
Most other NLEs offer similar features - even the free ones that come bundled with capture cards.
If you don't want that much control, I see other software advertised that looks like it might be good. I found DVDSlideshowGUI to be really hard work and wouldn't recommend it at all.
Cheers,
David.
Thank you both for you input, it helps a lot.
Would I find DVDslideshowGuI and Sony Vegas software on downloads.com or another site?
I have JVC Power Producer, Director and Windows Movie Maker but have not tried to scan pictures into them but have used them for importing video files. I liked Windows Movie Maker but had to put the files into an AVI movie to import them into WMM.
It can get complicated.
I appreciate your help. I was approaching it backwards!
At least give DVDSlideshowGUI a try, I found it very easy to use. But of course software "ease of use" can be a subjective thing...
Just click on the links in the posts above, no need to go trawling downloads.com!
Here's a tutorial for DVD slideshow GUI:
http://download.videohelp.com/tin2tin/tutorials.html
Thanks again, I will check out DVDSlideshowGUI
You scan pictures using a scanner. (!)Originally Posted by newbe tech
The software you use with the scanner is usually a photo editing package.
Video software has no place in this part of the process! You save the photos as jpegs (usually) from the photo editing software, and then load/import these into the video editing package or DVDslideshowGUI.
Hope this helps.
Cheers,
David.
Creating Menu Based Blue Ray with HD & SD footage
By RaV4MaN in forum Authoring (Blu-ray)Replies: 7Last Post: 5th Jun 2009, 20:46 -
Sepia Tone images and photographs
By bryankendall in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2008, 06:51 -
Video Footage, Rotating the footage.
By nikon1898 in forum EditingReplies: 2Last Post: 14th Jun 2007, 04:54 -
digital photographs into which slideshow software
By bonscott in forum Newbie / General discussionsReplies: 5Last Post: 4th Jun 2007, 08:55
