    in a situation where you'd like to preserve as much laptop battery life as possible, would it be recommended to play video files off of the Hard Disk or off a flash drive? I'd guess the flash drive, assuming the hard drive powers down due to non-usage, but it does take some power to operate the flash drive as well (light turns on, etc). Simple, non-HD divx/xvid files - nothing that would require high data transfer rates, so the files will play fine from the flash drive. Just wondering about the power usage.
    Thanks!
  2. Member midders's Avatar
    A flash drive uses a fraction of the power of an HDD (no moving parts), but it is unlikely that you will be able to get the internal HDD to power down whilst you are watching a video due to pagefile usage, etc. If this is the case then using a flashdrive is an additional power-drain and you'd be better of using the internal HDD. Or better still, get an internal SSD.
    Slainte
    midders
  1. Good Battery Life
    By Arlo in forum Portable Video
    Last Post: 22nd Apr 2009, 14:52
  2. Play dvds from dvd drive or from hd to save battery power?
    By denise4gb in forum Newbie / General discussions
    Last Post: 2nd Nov 2007, 21:29
  3. MiniDv battery life length?
    By capman21 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 12th Apr 2007, 14:33
  4. Harmony 688 - battery life
    By bobogs in forum Newbie / General discussions
    Last Post: 9th Apr 2007, 17:04
  5. battery life-expectancy?
    By Red96TA in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 27th Dec 2004, 12:07
About   Advertise   Forum   RSS Feeds   Statistics   Tools
