VideoHelp.com Forum
Results 1 to 9 of 9
    1.3.0.7 build 738 on Vista Business SP2
    In Project Settings, Video, I ensured that "DVD 4.3GB" was selected. The resulting .iso is almost 5GB. There's definitely a bug... either DVD Flick is not compressing video properly, or it isn't warning that the resulting image is going to be too big.
    ETA: This DVD was made with six .mkv files, each about 700MB, for a total of 4.37GB according to Windows.
    What is the combined running time of those MKV files ?
    Unless each MKV file was already DVD compliant, then chances are you are trying to fit way too much on a single DVD. Each mkv file will be re-encoded to meet the DVD spec. If each MKV is, for example, a 50 minute TV episode encoded with H264, then you are trying to fit almost 6 hours on a DVD. This is a big ask, and will look awful at full DVD resolution.
    For standard downloaded source encoded with H264 or Divx/Xvid, expect the size to increase by a factor of 3 - 4 times.
    If each of these files is a full movie (90 minutes or so) then put one per DVD.
    It would help if you posted a Tree view mediainfo output of the one (or more) of the source mkv files.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    A little less than 30 minutes, so less than three hours in all.
    General
    Complete name : C:\Videos\My_Random_Video.mkv
    Format : Matroska
    File size : 746 MiB
    Duration : 28mn 19s
    Overall bit rate : 3 683 Kbps
    Encoded date : UTC 2009-06-09 04:13:28
    Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Nov 7 2008 17:24:23
    Writing library : libebml v0.7.8 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Muxing mode : Container profile=Unknown@3.1
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 28mn 17s
    Bit rate : 3 226 Kbps
    Nominal bit rate : 3 295 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.146
    Stream size : 653 MiB (87%)
    Writing library : x264 core 67 r1162M f7bfcfa
    Encoding settings : cabac=1 / ref=3 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=240 / keyint_min=24 / scenecut=40 / rc=2pass / bitrate=3295 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : English
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 28mn 19s
    Bit rate mode : Constant
    Bit rate : 384 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 77.8 MiB (10%)
    Two-pass encoding or single pass quality based encoding ?
    Personally, I moved from DVD Flick to AVStoDVD because DVD Flick hasn't been updated in a while, and the last couple of released had issues. AVStoDVD uses the same encoder (HCEnc), has better menu capabilities, and is worth a look.
    Beats me!
    Thanks, I'll give that a look.
  6. Always Watching guns1inger's Avatar
    The encoding method is one you choose when you set up the job. 2-pass should be very accurate in file sizes, however the quality based encode attempts to calculate the best numbers, and if it misses, you don't get the file size you expected.
    I didn't see an option for that in DVD Flick. I was able to shrink the resulting image with DVD Shrink, though, and it plays.
    I'm trying with AVStoDVD now. With that, I see a checkbox for 2 Pass Encoding, which isn't checked by default so I left it alone.
    It seems like AVStoDVD is faster than DVD Flick, unless it does more steps... we'll see!
  8. I'm a Poll Super Moderator johns0's Avatar
    You shouldnt post the episode names cause they are are made by warez groups and thats against the rules here.
    Ben Johnson-I didnt take any stereos!
    OK, the Emperor is wearing his new clothes now.
  1. DVD Flick & AVStoDVD issues ...
    By iCaptainChaos in forum Video Conversion
    Last Post: 9th Aug 2011, 10:19
  2. dvd flick turned my iso into a winrar...
    By weezie1920 in forum Video Conversion
    Last Post: 8th Nov 2008, 10:02
  3. DVD flick region issue
    By 123fish123 in forum Newbie / General discussions
    Last Post: 16th Jun 2008, 22:25
  4. DVD display size issue
    By tanshul22 in forum Software Playing
    Last Post: 28th Nov 2007, 19:13
  5. DVD Flick issue
    By saspgmr in forum Video Conversion
    Last Post: 17th Aug 2007, 06:05
