VideoHelp.com Forum
Results 1 to 11 of 11
    Which DVD player plays the most downloaded file types for under $50? Right now I have a Phillips DVP 642 it only plays about hald of the file types I throw at it so which dvd player do you recommond
  2. Member hech54's Avatar
    Give us some examples of the types of files you are talking about?
  3. Man of Steel freebird73717's Avatar
    If you can stretch your budget to $100 I'd suggest the WDTV. It will play pretty much anything you throw at it from a thumb drive or external hard drive.
    Donadagohvi (Cherokee for "Until we meet again")
    My Video Tools :: Free Security Software :: Ubuntu Antivirus Rescue CD
    AVI Divx WM Mpeg
  5. Member hech54's Avatar
    Originally Posted by DJboutit
    AVI Divx WM Mpeg
    According to many Amazon.com reviews.....your player already plays all of those except "WM"(I'm guessing you mean Windows WMV?). It's what is INSIDE the .AVI file that you need to verify. Many describe .AVI as a "container" in which you can put many different combinations of video and audio....not just Divx/Xvid which the Philips supports.
    I am looking to upgrade so which dvd player should I get
  7. Member MOVIEGEEK's Avatar
    I agree with freebird, the WD media player or Seagate FreeAgent is your best bet.
  8. Philips 5990 or 5992, lots of topics on these if you look & they made custom firmware.
  9. Member hech54's Avatar
    Changing players will not guarantee that you can play "the other half" of the files you
    say the Philips cannot play....especially since you do not seem to know what video codec
    is used in those files that won't play. There are several very good free programs that will tell
    you exactly what video codec is in that file that will not play. GSpot is one of them.
    Do some homework before you buy. The next player may play the other half of the
    video files....but not the ones your present player plays...
    I am using currently Sony DVP-NS710H/B. It's an awesome standalone player.
    http://www.newegg.com/Product/Produc...82E16882105309
    You need to read this
    http://forum.videohelp.com/topic352457.html
    I have the old DVP-642 too. Every single one of the things in this list is a problem for this player. Many/some of them will be problems for ANY player that you buy. WMV support is very rare. WMA support is less rare.
    The Sony recommended by bulava doesn't state any ability to play any of the formats you mentioned. I would not recommend any Sony player given their constant anti-consumer stance, lack of quality and inability of the players to be made region free.
    Your price range is not realistic. You'd do better to save up a little and follow MOVIEGEEK's advice. DVD players are significantly more fussy about what they will play than media players are. I haven't fully tested my oldish WD TV player, but I can only think of one potential Divx issue in that list above that might be a problem for the WD TV player and that's the use of GMC with 3 warp points. Even that might work, but I don't know.
  1. Any SD DVD Player That Plays AVC File?
    By wulf109 in forum DVD & Blu-ray Players
    Last Post: 11th Nov 2011, 12:18
  2. File types and DVD player
    By rogmath in forum Newbie / General discussions
    Last Post: 7th Jan 2011, 14:24
  3. Philips DVP642 vs DVP3560 Which Player plays More File Types
    By DJboutit in forum DVD & Blu-ray Players
    Last Post: 3rd Dec 2010, 14:39
  4. Blue Ray player file types
    By plasmannc in forum DVD & Blu-ray Players
    Last Post: 13th Dec 2008, 18:32
  5. Help with burning a .vob file to DVD so it plays on a dvd player
    By Volume in forum Newbie / General discussions
    Last Post: 1st Nov 2008, 11:41
