Does anyone know of a good program that I can run, open a VOB and have it extract the subtitles for me?
I tried using using this one application called SubRip V1.50 Beta 4 and its driving me insane with having to go through letter by letter for over an hour and then after each sentence telling me theres a problem and showing an error of somekind that states. "This subtitle item cant be processed. Possible bad advanced OCR setup or none space between subtitle lines" then it just says item skipped. I dont know whats going on with it.
Is there a better app or way to do this?
I never had a problem like that with Subrip. You can try DVDSubEdit instead.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
Working with just one VOB out of the group is also never a good idea.
ok well I have the VOB file opened and all setup in the DVDSubEdit program. Now how do I save them as an srt file?Originally Posted by träskmannen
also I dont wish to save subpics, I believe I wish to save the softsubtitles as text
The only way to do that is to OCR, just like you're trying to do.Originally Posted by darkdream4
There is a button labeled "Run OCR" in the lower, right corner. Click it and wait while the OCR-process runs. When it is ready the button "Save as .srt" which now is grayed out should be active.Originally Posted by darkdream4In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
Yeah I kinda found that out. Now the only trouble Im having is getting the subtitles to show when I use MKVMerge. They work in VLC media player but not windows media player anymore. I have it explained here. http://forum.videohelp.com/topic377981.htmlOriginally Posted by träskmannen
Do you need text based subtitles? If you are ok with idx/sub you can use VSRip. Also, many DVDs carry closed captions as well. You can use something like ccExtractor to extract those (or VSRip as well).
Extracting frames from VOB files
By omkar.parkhi in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2011, 16:25 -
Extracting subtitles from Video_TS
By phunkidude in forum MacReplies: 4Last Post: 9th Apr 2010, 09:40 -
Extracting Subtitles From VOB Problem
By darkdream4 in forum DVD RippingReplies: 1Last Post: 6th Jan 2010, 05:28 -
By Boiler98 in forum MacReplies: 5Last Post: 24th Jun 2008, 08:21 -
Extracting hardcoded subtitles-does anything actually work?
By kpic in forum SubtitleReplies: 3Last Post: 2nd Jun 2007, 06:34
