VideoHelp.com Forum
  1. hello everytime i burn a dvd when the disc ejects it knocks off my wireless internet on my computer. i mean that the internet on my computer cycles when the disc ejects it also does it when i use my dvdrom
    The only time I have seen something like this was with an older computer with a small power supply and a wireless usb dongle. Certain functions meant the power supply could not send enough power to the wireless usb, and the connection would drop out.
    I suspect this could also happen with similar usb devices on cheap usb hubs.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  3. gunslinger is there a simple fix
    Put in a bigger power supply, change to ethernet, or try a PCI based wireless card instead of a dongle, and never put a wireless dongle on a hub.
  5. gunslinger her is a dumb question on my part but could i take a power line adapter and set it up.. in other words if i put the adapter behind my computer and hooked the ethernet cable to it would it connect to my wireless router like that. your help is greatly appreciated
  6. Always Watching guns1inger's Avatar
    Do you mean ethernet over power adapters ? Should do what you need, and will be much faster than wireless.
    Similar fault here with instructions which may resolve the fault
    The problem appears to be with the wireless configuration or its service in background
    It's another os bug
    Ps : Zercool fill in some computer specs and include wireless device make / model ... it helps in diagnosing the issue
  1. Wireless Internet Connection Questions
    By hech54 in forum Computer
    Last Post: 28th Nov 2011, 09:38
  2. Replies: 5
    Last Post: 20th Jan 2011, 19:57
  3. Replies: 17
    Last Post: 29th Sep 2010, 14:19
  4. High-speed internet through wireless network? Help!
    By Super Warrior in forum Computer
    Last Post: 18th May 2007, 11:34
