Hi,
I need to create AVI XviD from a video produced by iMovie. I have exported from iMovie a couple of different ways (MP4 and .mov) and the same thing happens. The picture is perfect, just no sound. As an example I'll include the details from the MP4:
filename: test2.mp4
Source format (identified in the drop zone): From MP4
Video: mpeg4, yuv420p, 640x480
Audio: aac, 44100 Hz, stereo
Target: To AVI XviD
Video: mencoder svid, 640x480, 940 kbps, 29.97fps, no crop
Audio: mp3, 4800 Hz, 128 kbps
To note, in the audio tab, thse are the settings:
Codec: .MP3 (encode audio is ticked)
Audio parameters
Audio bitrate: 128
Sampling 48000 Hz (changing it to 44100 does not change things)
Channels: Stereo
Mode: CBR
Audio track: 0
Invert mapping OFF (changing it to ON does not change things)
Audio Gain +0
Add audio.. (blank)
When I encode, this is the start of the output (asterisks mine):
If I change audio track to 1, it gives the error about being unable to find (2). Change it to 2, it says it can't find (3), and so on.Code:Encoding started on Wed Jan 6 10:00:47 EST 2010 MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team Mac OSX static build for ffmpegX FIXME:Hardenabling SSE and SSE2 without detection CPU: Intel (Family: 6, Stepping: 8) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x7f6843 ISO: File Type Major Brand: ISO/IEC 14496-1 (MPEG-4 system) v2 Quicktime/MOV file format detected. VIDEO: [mp4v] 640x480 24bpp 29.970 fps 0.0 kbps ( 0.0 kbyte/s) *****MOV: selected audio stream (1) does not exists***** [V] filefmt:7 fourcc:0x7634706D size:640x480 fps:29.97 ftime:=0.0334 xvid: using library version 1.2.-127 (build xvid-1.2.0-dev) Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=640 h=480] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4) ========================================================================== VDec: vo config request - 640 x 480 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect. SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter videocodec: XviD (640x480 fourcc=44495658 [XVID]) xvid: par=0/0 (vga11), displayed=640x480, sampled=640x480 xvid: CBR Rate Control -- bitrate=940kbit/s Writing header... ODML: vprp aspect is 4:3. Writing header... ODML: vprp aspect is 4:3. Skipping frame! .......... etc
iMovie seems to only allow me to save audio as aac. But ffmpegX converts a completely differently-sourced MP4 with aac audio fine (MP4, video h264, yuv420p, 320x240, aac, 48000 Hz, stereo)
This makes me think something weird is going on with iMovie's output. I can't think of what else to try. Suggestions?Code:Encoding started on Wed Jan 6 10:10:13 EST 2010 MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team Mac OSX static build for ffmpegX FIXME:Hardenabling SSE and SSE2 without detection CPU: Intel (Family: 6, Stepping: 8) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x1dfe110 Quicktime/MOV file format detected. VIDEO: [avc1] 320x240 24bpp 29.969 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:7 fourcc:0x31637661 size:320x240 fps:29.97 ftime:=0.0334 ========================================================================== Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding) AUDIO: 48000 Hz, 2 ch, s16le, 64.7 kbit/4.22% (ratio: 8093->192000) Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio) decoder) ========================================================================== Opening video filter: [expand osd=1] MP3 audio selected pect: 0.000000, round: 1 Opening video filter: [scale w=320 h=240] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264) ========================================================================== Forcing output fourcc to 58564944 [DIVX] VDec: vo config request - 320 x 240 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is undefined - no prescaling applied. SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter videocodec: libavcodec (320x240 fourcc=58564944 [DIVX]) Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Skipping frame! ........ etc
((edited to add description at the top: "The picture is perfect, just no sound. "))
This seems very similar to the issue mentioned in the MP4 to AVI - no sound, no subs thread. The inverted stream order is messing with the "-aid 1" mencoder option. I've come to consider this an ffmpegX bug.Originally Posted by rikyo
You could go command line without the "-aid 1" option,
or reverse the streams manually with MP4Box (1) or QuickTime Pro (2).
You can't avoid the inverted stream order with Apple's apps, as this seems to be build into QuickTime export functionality.Originally Posted by rikyo
Thanks very much, Case. I had skimmed that thread (and all the others I could find) and not fully understood the final post it until I wrote all of the above. Reading that thread carefully, it indeed seems to be the problem you describe here. I would consider it a bug, too. Thank you for confirming that it was to do with the iMovie export.
I am needing to convert files for a very specific limited-time purpose and should only need a week or two's worth of use (for now) so I have just tried the DivX 7 Converter, which gives a 15 day free trial. The output of that program seems to play very happily on the particular fussy piece of equipment I'm doing this all for!
I am a little hesitant to learn to use the command line for ffmpegX right now in case I miss something else important (and I don't have a lot of time for this project). I'll try the command line options if I need to come back to it. Overall, it seems a very neat program, so I'll very likely be back! Thanks again.
ffmpegX: no sound when converting a imovie *.mov-file
By acid_burn in forum ffmpegX general discussionReplies: 2Last Post: 27th Dec 2011, 00:40 -
From Vegas to iMovie - Does the version of iMovie matter?
By and in forum EditingReplies: 4Last Post: 11th Dec 2011, 20:05 -
What is the best HD output settings from iMovie to YouTube upload?
By NJRonbo in forum MacReplies: 3Last Post: 18th Nov 2010, 10:14 -
iMovie HD 6.03 Project: Equalizing sound on movie clips?
By iMacMan in forum MacReplies: 2Last Post: 30th Jan 2008, 03:53 -
Does this output sound right in VD?
By php111 in forum Newbie / General discussionsReplies: 0Last Post: 6th Oct 2007, 16:00
Statistics
Newest guides
Latest tool updates
New media comments
