Firewire port of my Sony DCR-PC108E Handycam is defective. What is the alternate way to capture recorded video from the camera. Please provide more than one options.
Results 1 to 9 of 9
Thread: Sony DCR-PC108E Handycam
1. Capture from another MiniDV camcorder.Originally Posted by ckbasak
2. Capture analog S-Video output using a capture card.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
1. If I capture S-Video output or through RCA, will the quality be same as DV capture? What will be the difference in quality between DV, S-Video and RCA capture?
2. My Laptop have usb port. If I use S-Video to USB converter what will be the quality? Is there any other device available for capturing in my Laptop, because I do not want to buy a new PC for adding capture card.
Originally Posted by edDV
A DV stream transfer over IEEE-1394 is a first generation to the file on disk (bit identical).Originally Posted by ckbasak
S-Video is a D/A analog conversion that needs to be redigitized during an analog transfer. The quality will be less.
Composite Y+C is a step down from Y/C S-Video because the chroma C is mixed with luminance Y and then must be separated before being redigitized.
For S-Video or composite, an analog to USB capture device can be used. These ususlly hardware encode to MPeg2 which is lower quality than DV. Quality usually varies by price.
Your best bet is to transfer your DV tape to disk on other equipment.Recommends: Kiva.org - Loans that change lives.
If, I use another camera for capturing through Firewire interface, the my laptop doesnot have any Firewire port. In this case, if I use one USB-Firewire adapter, then what will be the quality? Does this difference in quality make any significant sense? because finaly I will make High Quality DVD.
Following link provide one USB - Firewire Adapter :
http://www.usbfirewire.com/Parts/rr-527950.html
Is this a good device?
No it doesn't work correctly. User reviews are negative.Originally Posted by ckbasakRecommends: Kiva.org - Loans that change lives.
If you capture from another computer over IEEE-1394 the quality will be an exact 720x576i copy from the tape to a hard disk file.Originally Posted by ckbasak
The "USB-Firewire adapter" has proven to not work. Best you can expect is 352x288 over USB (quarter resolution webcam format).
Your other option is analog capture.Recommends: Kiva.org - Loans that change lives.
Looking For Something Better Than a Sony Handycam DCR-DVD105
By PeripheralVisionaryX in forum Camcorders (DV/HDV/AVCHD)Replies: 3Last Post: 21st Jun 2011, 13:11 -
Cable for New Sony HandyCam DCR-HC28
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD)Replies: 25Last Post: 21st Feb 2011, 17:15 -
Sony Handycam DCR-HC53E -- help!
By Gew in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 30th Jun 2010, 17:52 -
Pulling video off my Sony handycam DCR-DVD92
By briandk17 in forum MacReplies: 3Last Post: 22nd Jan 2008, 08:18 -
Sony Handycam - DCR-HC20E
By nzmikey in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 04:17
