    Today I encoded a FRAPS video to .m4v in Handbrake (720p H264 3Mbps 2-pass AAC audio). The video came out perfectly, no sync issues or choppiness.
    HOWEVER, when I uploaded it onto youtube....... youtube stretches the video length from 5mins to 10mins... then destroys it by making it completely out of sync & choppy as hell. (even the audio stutters like crazy)
    I know for sure this isn't my internet's fault, because I can view other ppl's HD videos just fine.
    Why is it doing this? I still have the original on my computer which runs completely fine.
    .m4v should be a video only file. if it has video and audio the correct container is .mp4 maybe you messed up the encoding settings. use mediainfo in text mode and copy and paste the output from the source and output files.
    General
    Complete name : C:\Other Videos\Shikigami no Shiro III - Stage 1.m4v
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 122 MiB
    Duration : 5mn 23s
    Overall bit rate : 3 164 Kbps
    Encoded date : UTC 2010-01-04 20:02:21
    Tagged date : UTC 2010-01-04 20:08:42
    Writing application : HandBrake 0.9.4 2009112300
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : avc1
    Duration : 5mn 23s
    Bit rate mode : Variable
    Bit rate : 3 000 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 30.000 fps
    Minimum frame rate : 24.000 fps
    Maximum frame rate : 30.000 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.109
    Stream size : 116 MiB (95%)
    Writing library : x264 core 79
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=301 / keyint_min=31 / scenecut=40 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 5mn 22s
    Bit rate : 160 Kbps
    Maximum bit rate : 207 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 6.14 MiB (5%)
    Text
    Format : Apple text
    Codec ID : text
    Duration : 5mn 23s
    Bit rate : 0
    Stream size : 14.0 Bytes (0%)
    Your framerate is VFR - variable frame rate. I don't think youtube understands VFR
    Indeed YouTube has some known issues using VBR, which are covered pretty extensively in their forums http://www.google.com/support/forum/...2b22ee0ffa7463
    A subsequent search of "audio sync" revealed a lot of reports about variable bit rate for audio being the usual culprit, ultimately making older uploads to the site lose sync. I'm having a similar problem and am trying to find a solution which makes Hnadbrake covert the video at a Constant bit rate.
  6. Member fitch.j's Avatar
    = Problem
  1. Replies: 16
    Last Post: 12th Mar 2010, 14:40
  2. Handbrake 0.94 MKV to M4V encoding
    By Scarpad in forum Video Conversion
    Last Post: 7th Dec 2009, 21:44
  3. VirtualDub -> Handbrake m4v, audio settings?
    By milltone blabbit in forum Audio
    Last Post: 30th May 2009, 23:33
  4. MP4 vs M4V (for Apple/YouTube)
    By Alain2007 in forum Newbie / General discussions
    Last Post: 18th Nov 2007, 23:58
  5. Encoded audio all messed up!
    By grimreaper36 in forum Newbie / General discussions
    Last Post: 18th Aug 2005, 21:15
About   Advertise   Forum   RSS Feeds   Statistics   Tools
