I'm new to the video editing scene and have just recieved (For Christmas) a JVC GZ-HD320.
I'm just a little confused at which AVCHD preset setting I should be using. I'm recording in the highest settings in the camera. Would the Premiere Pro preset change when I change the quality setting on the camera?
I figured out, through some research on these forums that AVCHD will not play smoothly on my pc. I want to know if editing the choppy playing AVCHD files on Premiere Pro will hard code the choppy'ness after I have exported the file to a respective file format?
Thread: Premiere Pro CS4 AVCHD Presets?
petronasGuest
if the quality setting only changes the bitrate, then no. if the setting changes the size of the image(like form 1920x180 to 1280x720) then yes.
no the choppiness is only from your computer being too slow to decode the video, it won't make any difference while encoding it other than it may take a really long time to complete.--
petronasGuestThank for the quick reply mate.
So what would be a good format to keep the edited files in?
I keep reading about h.264 but there are like 30 different sub headings under that container in the Premiere Pro CS4 presets...
Something for storage and something for youtube?
Iam struckling too as iam kind of same situation. I managed to get one sample movie but now when i try to encode it i can not find proper settings. I tried directly from premiere no luck. Then i use encore cs4 and i choosed blu ray image so i could easily test it with pa blu ray players like total theathre and cyberlink. None of the players would regonize this image. I use h.264 coded and doly sounds. When i browse through blu ray image i can find video file but no sound there at all. Also i noticed that this one transition makes picture look all jerky. So its not so simple as people are saying.
Premiere CS4 can't import AVCHD
By cheerful in forum EditingReplies: 24Last Post: 6th Mar 2012, 10:01 -
Correct Presets in Premiere CS4 and AME?
By 3DHDAnaglyph in forum Authoring (Blu-ray)Replies: 13Last Post: 26th Oct 2010, 07:34 -
AVCHD or HDV Capture in Premiere Pro CS4?
By AjSVB in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 2nd May 2010, 13:08 -
AVCHD and premiere pro cs4 demo!
By crossbrand in forum EditingReplies: 8Last Post: 7th Jul 2009, 12:19 -
Exporting AVCHD from Premiere Pro CS4
By jodal in forum Video ConversionReplies: 14Last Post: 29th May 2009, 07:12
Statistics
Newest guides
Latest tool updates
New media comments
