Hi!
I have the video but the audio is bit delayed.
Here is the info from MediaInfo
Can someone plz guide me how to fix it.Code:General Complete name : D:\Movies\Wake Up Sid.mkv Format : Matroska File size : 386 MiB Duration : 2h 20mn Overall bit rate : 385 Kbps Encoded date : UTC 2010-01-05 00:41:16 Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L2.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Muxing mode : Container profile=Unknown@2.1 Codec ID : V_MPEG4/ISO/AVC Duration : 2h 19mn Nominal bit rate : 306 Kbps Width : 576 pixels Height : 208 pixels Display aspect ratio : 2.769 Frame rate : 29.970 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.085 Writing library : x264 core 68 r1183M f21daff Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=5 / psy_rd=0.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=306 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : A_AAC Duration : 2h 20mn Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Resolution : 16 bits Language : Hindi Menu 00:00:00.097 : en:00:00:00.097 / en:00:00:00.097
Results 1 to 1 of 1
Thread: MKV: Audio out of sync
Audio out of sync in MKV file.
By Colin-uk in forum Video ConversionReplies: 14Last Post: 14th Oct 2011, 12:50 -
.mkv to .avi audio is out of sync
By gartzo in forum Video ConversionReplies: 3Last Post: 10th Jun 2011, 16:12 -
Video + Audio (.mkv) sync with...?
By highend in forum EditingReplies: 3Last Post: 7th Apr 2011, 17:35 -
problem with mkv audio sync
By movelikeme in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2010, 17:49 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
