VideoHelp.com Forum
    Hi
    I have a newbie issue that is really bugging me . I have backed up some BR movies and then copied the main m2ts movie file onto my hard drive. When I use Vista Media Centre the file plays fine with no issues, however when I use Win 7 Media Centre the video plays, but I get the commentary audio track instead of the normal audio track. The mm2ts files have not been touched in anyway. Any ideas what is happening? If I convert to mkv and select the right audio stream would that fix it?
    Thanks in advance
  2. Mod Neophyte Super Moderator redwudz's Avatar
    Unless you can select the correct audio track in Media Center, probably better to run them though a program like tsMuxeR first and just select the correct audio there, then mux that to a new .m2ts file. Other programs may work better for this.
    And welcome to our forums.
    Or use MakeMKV, ToNMT, Clown_BD to make a single ts or mkv.
    Originally Posted by Bob Badger
    Hi
    Thanks in advance
    Why did you remove the .m2ts file from the blu ray in the first place??
    ocgw
    pace
    Athlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
    http://forum.videohelp.com/topic368691.html
  1. Recommended Media Centre?
    By tommy2010 in forum Media Center PC / MediaCenters
    Last Post: 16th Sep 2010, 14:47
  2. Replies: 0
    Last Post: 14th Mar 2010, 12:28
  3. media centre pc
    By bouloux129 in forum Media Center PC / MediaCenters
    Last Post: 21st Aug 2009, 04:23
  4. Multiple issues with Media Centre...
    By Samantha_I in forum Media Center PC / MediaCenters
    Last Post: 3rd Mar 2009, 10:59
  5. Hyper Media Centre Advice
    By greer1988 in forum Media Center PC / MediaCenters
    Last Post: 8th May 2008, 06:14
