VideoHelp.com Forum
    Hi I just bougth a Yamaha DRX 730 ioand I cant find no hacks to make it region free, anybody can help me:
    thanks
    math
  2. Member hech54's Avatar
    You should have looked to see if it was hack-able BEFORE you bought it. Some can never be hacked.
  3. Bom dia Math,
    check this forum http://forum.pioneerdivx.net/viewtop...?p=15534#15534. Your Yamaha player has a Pioneer firmware. The patched firmware version can be found on this site.
    First you have to register and log in into the forum (only after registering yourself you are allowed to download the patched firmware). Read the whole forum. Download the CD ISO File (S8CA1246_patched_CD_ISO.zip), burn the image on a CD, don't forget to label the CD "PIONEER" otherwise it might not work, put the disc in the tray and follow the on screen instructions (press PLAY when you are asked, remove the disc from the tray when it opens).
    After that you have a "multiregion switch": to change to region 0, hold ENTER until player restarts; to change back to original region, hold CLEAR until player restarts. The OSD of the player nicely reports "Region 0" after doing this.
    Hope to have helped.
    Thank you very much about the ISO file!! It worked!!!!! Now my player is free for the world!!! lol
    very best!
    math
    Hello! I also have a Yamaha 730 which is region 1 and would very much like to make it region free.
    I downloaded the ISO file, burned a DVD but the player said it couldn't read this disk.
    I burned a second DVD and got the same msg from the player. Can't read the disk.
    I welcome your help. Thanks in advance.
  6. Hi lordeingles,
    I think you should use a CD not a DVD, but I am not sure.
    Are you sure you burnt the image correctly? What files do you have on the CD after burning? If you have a file with the extension .ISO on the CD, this is not good. The CD should contain a file called "S8CA1246.BIN" after burning the image and be labeled "PIONEER".
    Then please consult your burning software manual on how to burn an image.
    Success!
    Ano,
    Thanks for the note. My unit has been region free for some months now.
    As you hinted, I eventually tried to burn it into a CD and it worked.
    lordeingles
  1. Daytek dvr 730
    By smilan291 in forum DVD & Blu-ray Recorders
    Last Post: 30th Sep 2011, 10:23
  2. Yamaha DRX-730; radio channels
    By takefive in forum Newbie / General discussions
    Last Post: 12th Jan 2011, 14:00
  3. how to change DVD player region code on Toshiba SDk 730
    By sashatheman in forum DVD & Blu-ray Players
    Last Post: 12th Dec 2009, 06:17
  4. LG LDA-730
    By Wanderlustus in forum DVD & Blu-ray Players
    Last Post: 6th Jan 2009, 10:38
  5. help Drx-710ul Doesnt Recognize Dvd+r
    By aqua in forum DVD & Blu-ray Recorders
    Last Post: 23rd Jun 2008, 22:57
