Does anyone know how to unlock the LG HT304SU? The one hack posted already, has a link that does not open properly. All other hacks arn't working... any ideas, links, codes etc. welcome. cheers.
Some hacks don't work anymore due to hardware and/or firmware changes by the manufacturer. Perhaps someone will see your post and respond with something that will work for you, but it is also possible that you will never be able to unlock your player. Many DVD players can never be unlocked.
thanks for the info, it seems the home entertainment co's
have got it wrapped up . . . . for now!
This is how I changed mine, hope it works for you.
With no disk press PAUSE + ''1472''
2. In my LG I got this EEPROM information
EEPROM: f1 00 d0 29 00 81 a0 20 57 00
3.I changed the value 29 to 09 (0 means all regions)
4.Turn off the DVD and wait a little before turn it on again
Then to check if code works
1. Press the Setup button on your remote control
2. Select TV Aspect and place the cursor on the 16:9 Wide option
3. Using your remote control enter the code 1, 3, 9, 7, 1, 3 and 9
4. Press the Enter button on your remote control
5. You should now see the version information screen stating Region 0, or 2 if the change failed..
6. Press Setup button on your remote .
Happy viewing.
hi just tried this method, it didn't work.
When I press pause + 1472 the unit display toggles between PAL and NTSU but I don't get the PROM displayed on the tv screen.
The check method works but so far its always 29 not 09.
I'm getting closer but my system must require an alternative method to prompt the EEPROM mode...
Any other suggestions welcome Thanks for imput so far . . . .
I tried again and it worked, gotta tap pause and type numbers in fast otherwise it won't work!!
Thankyou for helping now I have a whole stack of films to watch!!
Hi guys. I tried this and got the region to 0 but I still can't play any DVDs. Can anyone help please
. Thanks
Unlock region code for Panasonic DVD-S1
By Jurgs in forum User guidesReplies: 0Last Post: 4th Jan 2011, 22:17 -
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 10:24 -
Sony DAV-DZ265K- multi-region code required.
By alllleg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Mar 2009, 10:22 -
By alllleg in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Mar 2009, 06:12 -
Help - Samsung R155 multi region unlock code needed
By pixie in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Aug 2008, 10:33
