The clip I have is of 2 people.
I want the music I selected to be at a lower volume when talking and at regular volume when not. I could simply cut the music and raise and lower the volume but this wouldn't be a gradual increase decrease. I'm not sure how to accomplish this in PP CS4. Can anyone help?
Smile
Smile
You can do it by using keyframes
Select the audio music track, in the effects control panel you can adjust the audio level. Hit the stopwatch to set a keyframe, then move the CTI elsewhere on the timeline, and adjusting the level will automatically place another keyframe. If you right click the audio keyframes you can make them ease in/out plus some other options . This changes the velocity curves and you can use bezier curves, and adjust handles for more accurate curves. You can visually see this in the timeline if you have audio volume keyframes enabled
Smooth accelerated video
By Bluelemmy in forum Newbie / General discussionsReplies: 17Last Post: 10th Apr 2012, 13:48 -
filter to smooth playback?
By kinglerch in forum EditingReplies: 14Last Post: 21st Oct 2011, 13:17 -
smooth slow motion
By nitrobaorder in forum EditingReplies: 22Last Post: 18th Oct 2010, 06:19 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
Premiere CS4
By piquenia in forum EditingReplies: 23Last Post: 3rd Sep 2009, 14:36
Statistics
Newest guides
Latest tool updates
New media comments
