please can someone help.....
i have searched everywhere nothing i do seems to work
I just bought easycap cable from ebay, it came with a disc but it was cracked...I am trying to install the device please can anyone tell me very simply what to do??
Thread: easycap
Check here.
http://easycap.co.uk/Ben Johnson-I didnt take any stereos!
does anyone hav one of these devices... do you know what the problem could be, cos serious i dont hav a clue what im doin
Try following this guide
Then this ... the driver link on the page leads to mediafire ... a site no one should enter with out an updated av product
If you have used the cd you need to use system restore point to go back prior to the install ... the cd is junk
With luck you should be up and running
And for future reference go here ... the manufacturer in china (its in english, lol)
i had the no sound issue and the drivers never installed properly.
i installed the k-lite codec and amazingly it sorted things out.
sound input needs to be set to usb in ulead not usbheadphone or mic.
sound quality in windows movie maker and power producer are
crappy but the ulead sounds a lot better. go figure.
quite a bargain for $9!
easycap help
By 11wesley11 in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2010, 16:08 -
Easycap Help !
By ellisharris in forum CapturingReplies: 0Last Post: 20th Mar 2010, 10:21 -
easycap
By neko_chan in forum CapturingReplies: 1Last Post: 30th Apr 2009, 03:41 -
** Easycap Problems **
By x_Cv_x_OuTrAgE_x in forum CapturingReplies: 1Last Post: 28th Apr 2009, 13:42 -
easycap
By stusy in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2008, 17:02
