I'm using the latest copy of HD DVD FAB and ripping the "Movie Only" to disk. I then use DVD Shink and burn the ripped files to my DVD. I can play the DVD just fine on the PC or another DVD Player - but when I try to play them on a new LG Home Theater system with built-in Blue-Ray disk it only see's the disk as a data disk, not a movie. So it won't play it. Any suggestions? Do I need to somehow finalize the disk differently for the BD player to see it is a movie? On the LG unit I can browse the disk and see the Video/Audio directories.
I've been using DVD FAB/Shink for a long time now - so pretty familiar with the steps - just something strange with the LB BD Player that is now new to me.
Thanks for any help you can provide.
Results 1 to 9 of 9
Either change to the Imgburn version of DVD shrink so it uses Imgburn to burn the disc, or output to a HDD folder, then use Imgburn to burn the results.
From time to time this is a known problem with the blanks, the "+" or "-" sometimes even the brand can have that effect. I have seen this with Panasonic dvdrs and Maxwell in the earlier days. It was a lot more common with earlier dvd players.
Thanks - Trying IMGBURN now and different disk - will post the results soon.
Ok, is there an easy way to tell DVD Shrink to use imgburn instead of the default Nero, that it looks for?
If the only issue is that one dvd player isn't playing them try a different type of disc first.
There is a version of Shrink specifically modified to use Imgburn. Download it from the Tools section (link to your left)Originally Posted by SMaldo
imgburn rocks - that did it. I guess that is the final death to DVD Shrink. Looks like I need to use imgburn going forward for it to work on my BlueRay player. Thanks for the help and quick responses everyone!!!!
DVD Shrink is not at fault. DVD Shrink does not burn anything. It uses the burning engine from either DVD Decrypter or Nero for burning, so which ever of these you were using was at fault.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
DVD's not playing properly after being burned
By Digger777 in forum Video ConversionReplies: 5Last Post: 25th Sep 2008, 23:52 -
Problem Playing DVD I burned
By hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 07:46 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 03:55
