VideoHelp.com Forum
  1. Member Ygramul's Avatar
    I have the latest ffdshow and XVid, but BSPlayer (v2.51 build 1021) still won't play any AVI or WMV (haven't tried other formats yet). The window size is correct, but it's just black. Windows Media Player 12 plays them no problem. I was trying to change the codec settings in ffdshow, but to no avail. I'm using Windows 7 Ultimate.
    Any ideas?
    http://www.videohelp.com/tools/Preferred_Filter_Tweaker
    Windows 7 uses its own DirectShow filters for decoding several audio and video formats. Using third party filters instead of the native filters is not possible without making changes to the Windows Registry. This tool allows you to configure your preferred DirectShow filters with just a few mouse clicks.
  3. Member Ygramul's Avatar
    Thanks. I figured I should just change the "preferred directshow decoding filters" to ffdshow in both (32-bit and 64-bit) columns (which I did), but that didn't cut it.
    I also tried the other two things Filter Tweaker has to offer in different combinations and... see above.
  4. Member Ygramul's Avatar
    Hellooooooo
    *echo*
    Originally Posted by Ygramul
    Hellooooooo
    *echo*
    The lack of response is probably because both Windows 7 and BSPlayer aren't used much around here. Your problem is probably a Windows 7 issue of some kind. Perhaps it would be good to look for help on the official BSPlayer forums.
  6. VH Wanderer Ai Haibara's Avatar
    Do you hear the audio being played?
    Try opening two instances of BSPlayer at the same time, with the same video. Does one instance play the video properly?
    You might also pick "VFW configuration" and "Video decoder configuration" from ffdshow's Start Menu folder, highlight Codecs in the left pane, and see if any of the codecs for the videos you're trying to play are set to 'disabled' in the Decoder column.
  7. Member Ygramul's Avatar
    I can hear the audio. Playing the same file in two instances of BSP doesn't change anything, still no video.
    I did that, didn't help
    I even tried two different kinds of ffdshow:
    ffdshow tryouts revision 3164 dec 14 2009 (msvc 2008, x64, unicode, r)
    and
    ffdshow tryouts revision 2527 dec 17 2008 (msvc 2008, x86, unicode)
  1. How to combine video with audio file and replace audio with video files ?
    By designbuyers in forum Newbie / General discussions
    Last Post: 8th Feb 2009, 11:12
  2. Replies: 15
    Last Post: 16th Jan 2008, 04:14
  3. Replies: 8
    Last Post: 30th Aug 2007, 07:27
  4. Replies: 1
    Last Post: 15th Jul 2007, 00:23
  5. bsplayer delete my files?
    By ieh4f in forum Computer
    Last Post: 23rd May 2007, 12:39
