VideoHelp.com Forum
Results 1 to 12 of 12
    Does anybody know of another program that does exactly what ANYDVD HD does? I just installed Win 7, ultimate and it is having compatibilty issues. It crashes my Windows everytime I install it.
    I apologize. I should have made the subject in the form of a question!!
    i think the only other choice is dvdfab.
    did you turn off user access control and then run the installer as admin?
    No but I will try it. Thank you! Will DVD FAB also do Blue Ray?
    Yes it does
  6. Member ricoman's Avatar
    What do you mean it is crashing your windows, what is it doing? I have had absolutely no problems with AnyDVDHD & Win7.
    I love children, girl children... about 16-40
    W.C. Fields
    I get Windows crashes, lockups, blue screen of death, etc. I have to go into safe mode and remove the program. I have even stopped it from loading at startup. I then start it and it locks the computer. Something is interfering with it.
  8. Member ricoman's Avatar
    Very odd, have you contacted Slysoft or Microsoft support? Excuse me, there is no such thing as MS support in my experience. The Slysoft forum might help.
    W.C. Fields
    I'll give it a look. Thanks.
    I haven't heard anything about this AnyDVD crashing systems either. I've been running AnyDVD since the release of the Windows 7 RC and have had zero problems with it. Not even with the purchased copies I have. I run AnyDVD on my Dell Mini 9, 2 desktops and 1 notebook and 1 tablet PC. No problems what so ever. This sounds more like a hardware problem Windows is having with your system.
    When you get BSOD, what does the text on the screen say? And BSOD is normally associated with hardware firmware conflicts
  11. Member ricoman's Avatar
    Maybe this will help, uninstall Anydvd, download Anydvd and right click on the AnyDVD install program and install as Administrator. If that doesn't work try the suggestion at the bottom of this thread:
    http://forum.slysoft.com/showthread....ight=windows+7
    W.C. Fields
  12. Does DVDFAB 1:1 Copy keep original audio or does it down convert it like it does for other options, ANYDVD does not work on a few movies and i want to use BD Rebuilder but need the original video and audio before i use BD Rebuilder
  1. Substitute to Streamtransport !
    By augustya in forum Software Playing
    Last Post: 15th Jul 2011, 12:30
  2. iuvcr substitute
    By marcolisi in forum Capturing
    Last Post: 4th Aug 2010, 13:50
  3. staxrip for mac substitute?
    By malakov08 in forum Mac
    Last Post: 9th Apr 2009, 00:57
  4. AnyDVD & AnyDVD HD 6.1.8.4 final
    By devilcoelhodog in forum Latest Video News
    Last Post: 11th Oct 2007, 21:27
  5. AnyDVD & AnyDVD HD 6.1.6.6
    Last Post: 30th Jul 2007, 16:07
