VideoHelp.com Forum
Results 1 to 10 of 10
    Hi Im looking for a good SD Digital Camcorder that records in MPEG2
    format unto an SD card, no HDD if possible, My range is up to $800.
    I need it to record some great footage for my line of work, electronic
    repair guides, so I need it to have great zoom quality.
    PS: I need Standard Def cause I only use Video Studio PRO X2, and my
    PC its an E6600 running WIN XP pro with 2GB ram. I think It can't handle
    HD mts files since my other option was buying a Canon vixia.
    thanks
  2. Member MJA's Avatar
    so nothing like the Canon VIXIA HV40 HD HDV?it shoots in both SD,and HD but on tape and it's only $699
    http://www.amazon.com/Canon-VIXIA-HV...2538276&sr=1-1
    mja has a good suggestion and your computer/software should handle HDV ok. the only problem may be a firewire port, does your computer have one?
    form corel -
    Non-Proxy HDV Editing
    * Intel Pentium 4 3.0 GHz, AMD Athlon XP 3000+ or higher with Hyper-Threading technology
    * 1 GB of RAM (2GB or higher recommended)
    * 16X PCI Express display adapter
    My Mobo its an intel BadAxe 1, dunno, haven't captured any video on it, I rather have the camcorder record on a memory card instead of tape tho =\
  5. Member MJA's Avatar
    if thats what you want.check the
    Canon Vixia HF200
    Canon VIXIA HF S100
    Panasonic HDC-SD1
    Panasonic HDC-HS250-K $694.30
    http://www.amazon.com/Panasonic-HDC-.../ref=pd_cp_p_1
    all at amazon.com
    The Panasonic HDC-HS250-K is very in teresting since it shoots SD and HD. when it records on Standard Def, what file format does it uses? since HD its .MTS, I hope the SD file is an MPEG2 one. thanks
    My editing software is Video Studio X2 and my DVD authoring software is DVDLab Pro
    so I need MPEG2 files.
  7. Member stedyone's Avatar
    The Pany HDC will record both mpeg4 (.mts) and mpeg2 in SD just as you thought. I use the Sony HDR-XR200 is SD mode and it works great. I got it refurbished for a song. I highly recommend refurbished consumer electronics as it is very 'green' and easier on the wallet.
    About the HDC-HS250-K, I can't find a compatible light source anywhere, does it have one? I mean can i buy one that can be plugged to the camcorder? thanks for all your replies. Im one step closer to my goal.
  9. Member MJA's Avatar
    no accessory shoe I think
  10. Panasonic Lumix DMC-FZ35 12.1MP Digital Camera does HD video onto SD cards, it's only $325 at amazon. Takes really nice still pics too.
  1. Aiptek Digital Camcorder, any good?
    By deadrats in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 12th Dec 2008, 13:54
  2. highdef dv or standard def dv
    By nivek_nayr in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Feb 2008, 19:37
  3. HD Videos on Standard Def.
    By mj585 in forum Newbie / General discussions
    Last Post: 7th Nov 2007, 20:50
  4. Need help choosing a good miniDV digital camcorder with still capability
    By newmom in forum Newbie / General discussions
    Last Post: 10th Jun 2007, 18:07
