Im trying to convert my copy of the blu-ray terminator salvation director's cut to a MKV but ripbot it picking the wrong files.
Its converting the director's cut part of the movie and not the move itself without the director talking.
Anyway to get around that?
The director's cut parts is only available through the pop up mene.
Or you can use ripbot for the video conversion tsMuxer to separate the audio you need for the movie and use MKVToolnix to mix that jont back together. A rip here and a code there and BANG!!!!
I usually play the longest couple of decrypted .m2ts files with VLC and find out which one is the correct file, then select it and the desired audio, then mux them with tsMuxeR and use that file with RipBot. Some BDs split the main movie and then BDInfo is handy to find out the playlist order. But RipBot usually gets it right on it's own.
How do I pick settings to optimally re-encode video for reduced file size?
By bootyhound1 in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 15:16 -
RipBot 264 not creating an output file
By oxfordyankee in forum Blu-ray RippingReplies: 3Last Post: 30th Jun 2011, 11:32 -
RipBot error - DirectShowSource: couldn't open file
By sweetalmond in forum Blu-ray RippingReplies: 2Last Post: 20th May 2010, 22:42 -
Ripbot Not Producing Locked File Size
By Rustsatz in forum Video ConversionReplies: 0Last Post: 15th Jan 2010, 09:40 -
AutoGK DVD to DivX, which VOB file to pick for the conversion
By rhythmofthecosmos in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2008, 14:25
