Hi all,
i'm working with ffmpegX on my iMac for a while, but I still have some problems. To convert a movie isn't the problem. Burning also going well. When I play it on my Pioneer system, it also going well. But when I play a DVD by my parents, who also have a Pioneer player, the DVD is shocking and finally will hang after say 15 seconds. By another friend, the DVD only shocks all the time. When I burn, also the ffmpegX Progress window is open en convert other movies. Could that be the problem? Or maybe the writing speed? Does anyone maybe know what the problem is?
Gtz,
Fleur
Thread: Problem with playing a DVD
What media ? (Brand, ID etc)
What burning app ?
What brand of media ? Memorex, verbatim, TY, local corner store bargain bin ?
Philips DVD+R 1-16x speed
Personally, I would try Verbatim blanks
But would that solve the problem? I don't think so... There have to be a reason, I think.
Saying something like this when people are trying to help you is a great way to not get any more help. If you know what is and isn't the problem, then why are you asking for help?Originally Posted by BS82
Your problem could be:
1) The DVD players don't like the media brand you are using. We recommend Verbatim because it's higher quality than what you are using.
2) Those other DVD players prefer DVD-R media, not DVD+R.
3) You have issues because the speed of your burns is too high. Believe it or not, it happens. Try 8x or 4x.
The most likely reason for your problem is #1.
LG FB162 DVD playing problem
By max_vini_vidi_vici in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th Jun 2011, 21:01 -
DVD Playing Problem
By Elevenius in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2011, 01:42 -
Problem playing DVD
By kevinlane in forum Newbie / General discussionsReplies: 7Last Post: 7th Apr 2011, 07:49 -
problem with playing on dvd
By shir32 in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2009, 18:55 -
DVD playing problem
By airwolfUK in forum Newbie / General discussionsReplies: 4Last Post: 24th Aug 2007, 04:19
