I don't know if this has been addressed, but, i've got some soft-style subs of some tv shows that i want to burn to dvd with encore. the files are in MKV format. I've got AVS video converter, but it always messes up the sub, rendering them like crap. i'd like to be able to just import the file into encore and burn from there.
that said, i am looking for ANY advice you guys can give me.
Extract the subtitles from the mkv using mkvextract. Try convert the subtitles to some format that encore support and you can have switchable subs.
Or use free all-in-one dvd converters like avstodvd or dvdflick, convert to a dvd-video with switchable subs from the mkv file.
thanks baldrick, but i do have a question: the subtitles are in soft-sub style, meaning they are not embedded in the video, will the program you suggested recognize that?
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 01:42 -
Backup DVD to mkv with soft subs
By rapaz in forum DVD RippingReplies: 28Last Post: 23rd Dec 2009, 23:16 -
Help with cycling through/disabling soft subs from mkv->DVD conversion
By herbster in forum SubtitleReplies: 1Last Post: 24th Nov 2009, 01:44 -
How to convert MKV with soft subs to AVI using DVDFab 6.x
By Shilar in forum User guidesReplies: 0Last Post: 28th Aug 2009, 09:15 -
Help!!! Need to Convert Soft Subs into MKV to work with WDTV
By carlos1969-1 in forum DVD RippingReplies: 9Last Post: 6th Apr 2009, 11:17
Statistics
Newest guides
Latest tool updates
New media comments
