How can I play avi files on my Vizio SV320XVT TV? I can connect my flash drive directly into the tv. When I try to play the avi files it tells me "video codec not supported." Any help would be appreciated.
Thread: AVI on Vizio TV
Check in your TV's manual what kind of AVI is supported, then ensure that the AVI's you try to play conform to that spec.
Manual shows video encoders supported "H.264/AVC." How can I make the files conform to that spec? Is their software?
Thanks for the response.
I used XviD4PSP to convert video files for my Vizio TV. It was trial and error, but i think that the settings that finally worked for me were:
Format - MP4
Audio - AAC
Video - H.264 (Progressive - i don't know if that matters, but that's what i was using)
Just adjust the bitrates and aspect ratio to fit your needs.
*just tried it and worked fine on my Vizio TV.
I will give it a shot. I really appreciate your help. Thank you!
Vizio P50HDTV Plasma RGB Gives No Signal
By MickeyMouse in forum DVB / HDTVReplies: 8Last Post: 7th Jul 2011, 18:54 -
Just bought a Vizio 32 inch.
By capman21 in forum DVB / HDTVReplies: 5Last Post: 25th Mar 2010, 16:25 -
TV comparisson: Vizio, Panasonic and Sharp
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 13:06 -
Vizio VBR-100
By Fraggel in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Oct 2009, 09:29 -
Bought a Vizio 22" LCD HDTV?
By sandman423 in forum DVB / HDTVReplies: 8Last Post: 31st May 2009, 00:57
