Verbatim BD-R 25GB 2X DataLifePlus White Inkjet Printable #96661 http://www.verbatim.com/products/det...71AA4C27793D81
What ink jet printer prints on these? I'm not into Blu-ray, so this may be a dumb question, but I thought Blu-ray had a larger diameter disc than SD DVD and CD.
Depends what the definition of the word inhale is.
The Blu-raydisc has the same physical dimensions as standard DVDs and CDs.
This is probably a typical flat, not glossy, Verbatim disc surface for inkjet printers. It's not bad, but something glossy like Taiyo Yuden't Watershield brand looks nicer. I don't think TY makes any BluRay media for sale in the USA at this time so the Verbatims are probably as good as you can get.
aedipuss is correct. Standard CDs, DVDs, HD-DVDs and BluRays are all the same size.
Youtube video:
http://www.youtube.com/watch?v=GtQAt...eature=related
The above one (Nimbie Sidekick) uses Epson to print directly on CD, DVD and BD (Blu-ray) discs. The printing job is automated for 100 discs. Refill the disc loader does not interrupt the printing job, easy to go a job of more than 100 discs if refill the loader before it goes empty...
The more expensive Epson printers like the Artisan series and up. A few pricier HP printers can also print CD/DVD. And some Canon printers can do it with modification. IIRC, you can buy a tray off E-Bay to make a Canon printer essentially a European model. A firmware or driver change may be involved as well, but someone will have to confirm.
The Epson Artisan 50 is about a hundred bucks and can do it. I got an Epson Artisan 725 all-in-one last month and am satisfied with it.Pull! Bang! Darn!
Thermal print on white inkjet printable disc? Ok?
By jlietz in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2007, 17:50 -
Prodisc S03 Inkjet Printable at Rima.com - print to the hub?
By virtual133 in forum MediaReplies: 0Last Post: 17th Jun 2004, 12:47 -
Does Beall inkjet printable have larger print area than Rite
By Jerry in forum MediaReplies: 1Last Post: 20th Aug 2003, 00:04 -
which inkjet printers print directly to printable dvd media
By pakman in forum DVD RippingReplies: 5Last Post: 6th Jul 2003, 23:04
