VideoHelp.com Forum
Thread: AutoGk Problem
  1. Member darkdream4's Avatar
    I get all kinds of files but not the video file. I can only see it in the preview but when I tell it to do the job I dont get any file for the video. Says Video compression error: the source image format is not acceptable (error code -2) when the VirtualDubMod opens on its own and starts to do the rest as the job is finishing.
    [12/29/2009 10:11:30 PM] AutoGK 2.55
    [12/29/2009 10:11:30 PM] OS: WinXP (5.1.2600).2
    [12/29/2009 10:11:30 PM] Job started.
    [12/29/2009 10:11:30 PM] Input file: C:\Documents and Settings\Aiden\Desktop\ElfenLied\VIDEO_TS\VTS_01_1 .VOB
    [12/29/2009 10:11:30 PM] Output file: C:\Documents and Settings\Aiden\Desktop\ElfenLied\VIDEO_TS\VTS_01_1 .avi
    [12/29/2009 10:11:30 PM] Output codec: XviD
    [12/29/2009 10:11:30 PM] Audio 1: Audio Stream 0 AC3
    [12/29/2009 10:11:30 PM] Subtitles: none
    [12/29/2009 10:11:30 PM] Format: AVI
    [12/29/2009 10:11:30 PM] Target size: 250Mb
    [12/29/2009 10:11:30 PM] Audio 1 settings: Auto
    [12/29/2009 10:11:30 PM] Started encoding.
    [12/29/2009 10:11:30 PM] Demuxing and indexing.
    [12/29/2009 10:12:36 PM] Processing file: C:\Documents and Settings\Aiden\Desktop\ElfenLied\VIDEO_TS\VTS_01_1 .VOB
    [12/29/2009 10:12:36 PM] Processing file: C:\Documents and Settings\Aiden\Desktop\ElfenLied\VIDEO_TS\VTS_01_2 .VOB
    [12/29/2009 10:12:36 PM] Source resolution: 720x480
    [12/29/2009 10:12:36 PM] Found NTSC source.
    [12/29/2009 10:12:36 PM] Source aspect ratio: 16:9
    [12/29/2009 10:12:36 PM] Analyzing source.
    [12/29/2009 10:14:42 PM] Source is considered to be hybrid (mostly NTSC).
    [12/29/2009 10:14:42 PM] Looking for optimal hybrid thresholds.
    [12/29/2009 10:14:44 PM] Found threshold of: 0.01
    [12/29/2009 10:14:44 PM] Output will contain 45037 frames
    [12/29/2009 10:14:44 PM] Decoding audio.
    [12/29/2009 10:16:11 PM] Normalizing audio.
    [12/29/2009 10:16:30 PM] Encoding audio.
    [12/29/2009 10:20:09 PM] Using VAQ in XviD
    [12/29/2009 10:20:09 PM] Audio1 size: 22,140,432 bytes (21.11 Mb)
    [12/29/2009 10:20:10 PM] Overhead: 1,801,472 bytes (1.72 Mb)
    [12/29/2009 10:20:10 PM] Video size: 238,202,096 bytes (227.17 Mb)
    [12/29/2009 10:20:10 PM] Running compressibility test.
    [12/29/2009 10:23:20 PM] Duration was: 3 minutes 9 seconds
    [12/29/2009 10:23:20 PM] Speed was: 11.89 fps.
    EXCEPTION: Open avi failed.
    [12/29/2009 10:23:20 PM] Job finished. Total time: 11 minutes 49 seconds
    Try open the VTS_01_1.ifo instead of the vob file.
    And if that wont help try (re)install latest xvid codec.
  3. Followthe link given in Q 6.7 of the AutoGK FAQ and see if it helps you to figure it out:
    http://forum.doom9.org/showthread.php?t=72679
  1. Problem with AutoGK
    By onlygk in forum Video Conversion
    Last Post: 2nd Jun 2010, 05:09
  2. Problem with rips + AutoGK
    By alpheus86 in forum DVD Ripping
    Last Post: 31st Mar 2009, 12:20
  3. Problem with Autogk
    By sunny3220 in forum Subtitle
    Last Post: 14th Nov 2008, 10:05
  4. Autogk Problem
    By sohancool in forum Newbie / General discussions
    Last Post: 2nd Apr 2008, 09:26
  5. AutoGK with VirtualDub problem
    By Deaf Raiders in forum Newbie / General discussions
    Last Post: 21st Jan 2008, 14:04
