I am new to this and I think I posted before, but I can not see my post.
Anyways, I am trying to join 2 AVI files using the program AVI/MPEG/WMV Joiner and I get the following error:
The audio streams have different sampling rates (15848 vs 15836) which may cause errors while merging! Do you want to continue?
And of course the program will not run and JOIN both AVI into 1 AVI.
Paul
Thread: avi audio stream
If the audio bitrates are the only issue try recoding the audio using virtualdub, set the video to "direct stream copy" and audio to "full processing mode" then under audio click "conversion" and set to "16000" or some like that. Then save the file, once done try merging them again.
I do not have the original AVI file. Both these files are downloaded and have different audio streams.
So, is there some kind of program that will fix this?
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
avi container with more than one audio stream?
By usta in forum Newbie / General discussionsReplies: 4Last Post: 27th Sep 2009, 04:35 -
Help with how to choose audio stream in avi to dvd conversion
By hibbs in forum Newbie / General discussionsReplies: 3Last Post: 25th May 2008, 23:50 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Replace audio stream in a DV AVI file
By dzoge in forum EditingReplies: 3Last Post: 6th Jun 2007, 18:57
Statistics
Newest guides
Latest tool updates
New media comments
