Hi,
i am looking for a tool, that converts a main movie of a blu-ray into a single m2ts file. It also should rip out the unwanted audio lines etc.
Normaly i use tsmuxer for this and it works great, but there a blu-rays where the main movie is splitted in to serveral m2ts parts and merging these file takes a lot of time (or i dont know which files must be merged). Is there a tool that will do this job for me. (analysing the blu-ray structur, possibility to select the wanted audio line etc and output this to a single m2ts file without recompressing)
Thanks in advance,
Martin
Results 1 to 9 of 9
Yes .. I know, but my challenge is, that i want a tool, that will do most of the job for me. For MKV i use MakeMKV, this tool does exactly what i want, but the ouput is MKV and not m2ts
The reason why i want m2ts and not mkv is, that my WD HD TV Live has some problems with MKV. MKVs with VC1 encoded videostream are out of sync, with a m2ts i dont have this problem.
Use bdrb in Movie-Only Backup mode. Select the audio that you want. If you want no compression, then use Custom Target Size in the Setup. This will create the one m2ts file you want.
You are dealing w/ "seamless branching discs"Originally Posted by Moondiver
Examine the disc w/ eac3to, BD Edit or BD Info to get the correct main movie .mpls file
Navigate to the correct .mpls file the same way you would navigate to the .m2ts main movie file and TsMuxeR will seamlessly join them for you as well as correct gaps and overlaps
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
I use DVDFab version 6 and it does exactly what you ask for. Are you trying to advertise for DVDFab?
Well, they are pretty good
Vu
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 18:25 -
Several blu-ray m2ts files to one single file?
By Mr Flibble in forum Blu-ray RippingReplies: 5Last Post: 14th Apr 2010, 10:34 -
Edit M2TS file ripped from Blu-ray Disc
By seven_deuce offsuit in forum EditingReplies: 3Last Post: 22nd Sep 2009, 20:41 -
help: when a blu ray movies is split into more than one m2ts file
By lodwales in forum Blu-ray RippingReplies: 1Last Post: 19th Sep 2009, 09:51 -
Creating a blu-ray disc from .m2ts and .srt file
By denada in forum Authoring (Blu-ray)Replies: 5Last Post: 26th Aug 2009, 14:29
I expect yada..yada..yada..is coming next :P :P
