I want to use the visulizer for dvd menus but cant find a way to capture it in high enough quality. The 2 screen recorders i have tried r very low quality avi. Can any one help?
Thread: How to record iTunes Visulizer
What screen recorders have you tried?
You might also set the compression for the AVIs the screen recorders generate to none or a lossless codec - if you have it set to a lossy codec, like DivX/Xvid, the system also has to compress while it's capturing, and depending on how powerful your system is, that could lead to frame dropping and losses in capturing quality.
Have you tried FRAPS?If cameras add ten pounds, why would people want to eat them?
itunes to popcornhour
By ggp759 in forum MacReplies: 0Last Post: 22nd Dec 2010, 14:26 -
avi 2 itunes
By kg4886 in forum Newbie / General discussionsReplies: 4Last Post: 22nd May 2009, 05:29 -
Issue with ITunes
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 14th Feb 2009, 15:21 -
iTunes damaged
By seven_deuce offsuit in forum Portable VideoReplies: 1Last Post: 26th Sep 2007, 21:02
Statistics
Newest guides
Latest tool updates
New media comments
