Hi
I've been looking in to getting a capture card for recording gaming from my PS3, I don't want to spend a fortune on one, So a HD one is not that important, A good quality SD one with 16:9 720x576 capture will do, Anyone recommened one?
Also i would like to ask if i can capture through my tv when playing on my PS3 or will i have to connect it up to the PS3 with splitters.
My tv is a 37LG5020 and has the following connections
Connectors type 1 x AV, 3 x audio, 1 x S-Video, 1 x Component video, 2 x SCART, 1 x RGB, 1 x VGA, 3 x HDMI, 1 x RS-232
Results 1 to 15 of 15
Thread: Capture card for PS3
People ask this question from time to time, but most of us here aren't gamers. If you want to search, we've had good answers to this question before. Search is broken within individual forums like Capturing, so you have to go to the top of all forums to search. I can tell you that you will need a card that can capture PAL60 video because some of your games may output that and most video capture cards cannot capture that. Using PAL60 as a search term may lead to some matches for your question. If I remembered what others had used I would tell you, so I'm not telling you to search because I just want to make you work to get the information. The recommended card was by some manufacturer I hadn't heard of and I don't remember their name.
I recommend the pinnacle usb tv tuners. The hdtv ones. THey have 16:9 recording modes.
One caveat - that is for recording off air broadcasts for capture to dvd. I never tried the 16:9 mode from external sources.
For that I use the hd pvr 1212. That records via component cables and fiber optic for surround sound (it can record via analog rca).
Now granted the hd pvr is rather pricey (I think its around 200.00 USD give or take - it should be cheaper used on auction websites). But the nice thing is it does record widescreen beautifully and gives you m2ts and mp4 recording options.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
I'm looking at getting the dazzle dvd recorder http://www.amazon.co.uk/gp/product/B...425P1W06PW06EV
Along with one of these cables http://www.amazon.co.uk/Plated-Tripl...3125052&sr=1-6
Do i need splitters? or will i be able to connect the cables directly into the back of my tv to record?
But seen has the dazzle dvd recorder has a s-video connection would it better to connect it up to the s-video on the tv for better quality?
Very few, if any, TV's have video OUTPUTS, they are all most likely INPUTS.
Don't know the answer myself but the PS3 may very well have two outputs active at the same time, if not, you will either need a splitter or use the output from the capture card. Most times the capture card output is very slightly delayed, making game play difficult if not impossible.
The Hauppage or the Blackmagic Intensity is usually mentioned for doing this, I used my old ATI card on an Xbox360 for this, it will cap 16:9.
Dazzle products often get exceedingly negative reviews here, have never used one myself.
Well hdtvs will most likely have at least an optical output for digital audio, probably not video though.
As for the ps3 and muli-outputs - it will simultanously output two audio sources with a more recent firmware upgrade. I don't know when they made that change but it was sometime in 2009. So if its a factory fresh model from early last year or before without a firmware upgrade you will need to upgrade it to enable the multi output function.
As for multi video output I do not know if it is capable of that. WHen I have dubbed from the ps3 I have used the capture software to view the video on the computer.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
If you want to record HD check out the Hauppauge HD-PVR. It loops component video to the HDTV and hardware encodes captured video to h.264.Originally Posted by restarts
The Black Magic Intensity uses a software codec to record large MJPEG files or records uncompressed to a multi-disk RAID.
The HAVA boxes take in HD component but downsize to SD for recording.
If you record SD with a cheap card, you need to run your PS3 in SD mode.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
I'd try checking if the PS3 can output to multiple connections instead of seeing if the TV can pass-thru the signal to a capture card. That way one output goes to the TV and the other goes to the capture card.
Most game consoles output one format at a time.Originally Posted by GSP_87
HDTV sets only have HD formats in, not out.Recommends: Kiva.org - Loans that change lives.
The ps3 can output multiple audio (in 2 channel mode). As mentioned I don't believe it can ouptut multiple video simultaneously.
I believe the PS3 has the ability to out put multiple video signals, mostly because the concept model had two HDMI ports on it.
The PS3 cannot output video via HDMI and one of its analog connection at the same time.
http://www.hometheaterforum.com/t/26...osite-and-hdmi
http://www.avsforum.com/avs-vb/archi.../t-946215.html
I don't think it can output video via its component connections and one of its other analog connections at the same time either.
I believe the only two video connections one could possibly use at the same time are composite and S-video. I think I remember a poster in another thread used a composite + S-video cable connected to the PS3 (instead of splitting the composite video output) to provide a better video signal for capture, but I can't find the thread to confirm it.Last edited by usually_quiet; 6th Nov 2011 at 08:19. Reason: spelling
Yeah, there's a big difference between a prototype and something that has to be manufactured at a certain cost.
All of the official output cables (Sony sells three separately in NA: Composite, S-Video, and Component) connect to the same "AV MULTI OUT" port, so it's an either/or scenario unless someone has hacked together a cable that can do more at once.I don't think it can output video via its component connections and one of its other analog connections at the same time either.
http://www.ps3devwiki.com/index.php?...s#AV_Multi_Out
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum CapturingReplies: 5Last Post: 16th Oct 2011, 20:38 -
Video card 1080p Vs ps3
By alolo in forum CapturingReplies: 4Last Post: 31st Dec 2010, 10:15 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Capture HD from PS3 ?
By squadjot in forum CapturingReplies: 3Last Post: 13th Oct 2008, 19:18 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum CapturingReplies: 1Last Post: 6th May 2007, 17:15
