Hi Guys/Girls,
I have a question about ripping DVD that are 4:3 as it stands I am ripping my DVD collection to my cyclone HDD player all file are 16:9 and Im encoding using xvid bitrate of 1mb(ish) two pass encoding with a res of 624x352 I beleive this is what tv and dvd rips are done when the "Scene" groups release them, but what is the res for 4:3 dvd as I have a TV from the 70's and its in 4:3 and I would like to keep they way then "scene" do it as the quality is good
Does any one know what 4:3 rips should be?
Cheers
Patrick
Thread: Ripping dimension for xvid avi
Forget the "scene" nonsense. Leave the frame size at 720x576. Then use the Xvid PAR/DAR flags to set the DAR to 16:9 or 4:3. See if your player obeys the flags. Doing this will preserve all the resolution.
If you really want (or need) to use square pixel encoding just use any 4:3 frame size ratio you want: 640x480, 576x432, 512x384, etc.
Tread lightly, because discussion of illegal downloads is forbidden here.
Anyway, 4:3 NTSC DVD is 720x480, but you can't rip at that resolution and get a 4:3 image because AVIs can't force an aspect ratio onto a resolution that doesn't match like AVIs can. To get 4:3, you either have to upscale slightly to 720x540 or go to a lower resolution.
But anyway, to get the results that you're looking for, just use AutoGK and use the pre-set file sizes: 700 MB for most movies, 350 MB for commercial hour long TV shows, and 175 MB for commercial half hour TV shows. It'll keep the proper aspect ratio.
Slideshow: Keep the original dimension of my photo?
By porta.bricherasio in forum Newbie / General discussionsReplies: 6Last Post: 30th Jan 2011, 14:29 -
bitrate/dimension issue
By Skizzarz in forum DVD RippingReplies: 29Last Post: 2nd Dec 2010, 08:17 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 14:05 -
DVD Ripping to AVI (XViD + Lame) through MKV Magic. Is it possible? How?
By Bonie81 in forum DVD RippingReplies: 3Last Post: 17th Apr 2010, 09:05 -
canon zr960 video dimension
By sheriffg in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 19th Dec 2009, 17:59
Statistics
Newest guides
Latest tool updates
New media comments
